Manual Trans Drain Plug part #
Old Apr 18, 2012 | 11:04 AM
Domepiece's Avatar
As the title says looking for the part number. Tried local stealership and they did not know. Anyone have the part number I could give them. I do not wanna use the shifter position sensor to drain it. Thanks. 2001 AE Max
Old Apr 18, 2012 | 11:17 AM
Galactica's Avatar
I just did mine and used the shifter position sensor. When you unbolt it, carefully twist it back and forth to work the seal loose and it will pop right out, no worries.
Old Apr 19, 2012 | 09:16 AM
DennisMik's Avatar
I think this is it, but I am not sure.
00931-2121A
Plug-thread
Reference # 13
http://nissan4u.com/parts/maxima/us_...llustration_2/
Old May 22, 2012 | 09:37 AM
Domepiece's Avatar
Anyone have a definitive answer? Its hard to tell from the above schematic if its right.
Old May 22, 2012 | 11:05 AM
dfj240's Avatar
Manual Transmission Drain Plug Part# For 2001 Manual Transmission:
32103-1MG0B
-Nathan
Old May 22, 2012 | 11:26 AM
Domepiece's Avatar
how positive are u? im checking around online and its coming up as 2005 on some sites. Its also coming up from multiple nissan and infinity vehicles so im not sure.
Old May 22, 2012 | 11:55 AM
dfj240's Avatar
I'm pretty positive. My system has rarely steered me wrong on a Nissan part number in 8 years so far, and if I was steered wrong it was more likely my fault than anything else. It's quite accurate.
For the 95-01 5-Speed Manual, the drain plug part# is: 31203-03E0A (which supercedes 31203-03E01)
For the 2001 Anniversary Edition 5-Speed Manual, and 2002-2005 6-Speed Manual, the drain plug part# is: 31203-1MG0B (which supercedes 31203-4N210)
That's what I show at least.
-Nathan
Old May 22, 2012 | 03:41 PM
Domepiece's Avatar
did not come up in the stealerships system... are those a different part number than them?
Old May 22, 2012 | 04:38 PM
DennisMik's Avatar
Have you asked the dealeship to look the part number up? What do they say?
Old May 22, 2012 | 09:57 PM
dfj240's Avatar
Those should be the Nissan part numbers in their system. I don't see there being any reason they wouldn't be there, even if they didn't stock them. That's rather odd.
http://nissanpartsasap.com/nissanpar...&illust_seq=01
Refer to the original post in this thread...
-Nathan
vingodine
45
May 21, 2016 12:46 PM
t6378tp
Aug 24, 2015 07:03 AM
Turbobink
Aug 15, 2015 07:20 AM
ef9
Aug 13, 2015 01:19 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
