Weird noise coming from front driver side wheel
so when im slowing down a bit or even driving i hearing this scratchy squeaky sound, i cant be my brake pads since i changed them like a month ago...a bad wheel bearing sounds more like a rumble so idk what it is anyone have any ideas????
Does it sound like a higher pitched wine, consistent with wheel speed?
I chased a noise just as described, turned out to be the inner bearing dust shield where the cv end buts up against the bearing in the hub assy. The actual seal was dry and made this scratchy wine as the car slowed down under say 30mph. Drove me nuts for quite some time, only heard it after driving for a bit, like a 10 min cruise down the highway and the noise was present. I figured it out when the cv boot tore and I removed the drive shaft. Things were really dry where the seal rode on the back of the cv joint. All it took was a nice wad of grease when i reinstalled the axle and it's been silent for years.
NOise in front end
Hey, did you fix this??
1995 Maxima SE
240K miles
I have 2 problems.. solved one still got the other.
1) There was a metallic 'clunk' when applying the brakes..of course, not all the time, but it was isolated to only when brakes were applied. I replaced the pins that mount the brake caliper and the noise went away.
2) There is a noise similar to when you run over the things on the side of the road (put there to wake you up). I have isolated it to when I apply the brakes , and turns or immediately after turns. Of course, it does not happen all the time.
Actions: Rotated tires, struts replaced, no ball joint problems, dust shields fine.
I figured if it is a bearing, it will be doing it all the time...confirmed tis with my mechanic.
I am stuck.. I think a caliper job might be in order.
SO, any answer to the original question?
1995 Maxima SE
240K miles
I've got this weird noise that recently started near the front driver side wheel also. I don't have abs and it only makes it while car is in motion. I don't kno if it'd the brakes yet but I know they are pretty worn down and need to be changed, but it sounds like a choo choo train, but its not that loud. It has no affect on driving the car its just annoying.
annoying.
annoying.
kingw323
20
Oct 21, 2015 08:36 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
BassAddictJ
Aug 4, 2015 11:38 AM
I have a noise there right now but seems only when car is moving. Need to take off and do CV boots on my axles.
