CA FS: 95 JWT ECU
Old Apr 30, 2012 | 03:14 PM
charliekwin's Avatar
FS: 95 JWT ECU - with extended redline
Hey guys,
I have a JWT ECU for sale. Sticker on it says "POP Upgrade Package" for a 95 fed-spec AT. This ECU does not have the extended redline. I had it in my 96 GLE for several years and it served me well, but I finally replaced the Max with a G35 last month, so now it's someone else's turn. Looking for $400; shipping included at that price. Images below.
EDIT: I contacted JWT to ask about the rev limit and they have confirmed that the ECU DOES have the extended redline. The contents of their email to me are below:
The JWT ECU has an engine redline moved to 7000 rpm. The automatic transmission controller still controls when the automatic transmission shifts, not the ECU. If you put the car into one of the lower gears (manually move the shift selector), you can then hold the accelerator pedal down and see that the engine rpm will continue way past 6200 rpm. We raise the rev limiter in almost all ECUs we upgrade unless someone specifies something different or a stock rev limiter.
Old May 4, 2012 | 08:36 AM
bump!
Old May 4, 2012 | 08:43 AM
What does this "pop upgrade" consist of?
Old May 4, 2012 | 10:12 AM
POP is the "Performance Optimized Programming," basically JWT's catch-all marketing term for the adjustments they make to the ECU (timing, fuel map, etc.).
Here's the JWT page for the ECU, which goes into more detail: http://www.jimwolftechnology.com/cus...asp?PartID=154
Old May 13, 2012 | 02:10 PM
bump
Old May 14, 2012 | 12:33 PM
maxboy325's Avatar
You sure no extended revs?
Old May 15, 2012 | 04:15 AM
wirelessdude04's Avatar
Only if it had extended rev ugh glws
Old May 15, 2012 | 01:10 PM
I had it in a 96 automatic and it would shift at 6200 RPM. Never any higher than that, so I have to assume it doesn't have the extended redline.
Now, JWT's own page seems to indicate that it has the higher rev limit, so *maybe* it would if it were used in a manual. But I'd rather be safe and say it doesn't have it than even unintentionally lead someone to believe it does and end up disappointed. Maybe someone with more knowledge could chime in.
Old May 16, 2012 | 07:32 AM
maxboy325's Avatar
With an auto trans the TCM takes over unless you manually shift the auto 1-2-D
Manually shifting it should show the extended revs
Old May 16, 2012 | 10:40 AM
CallMeThatOneGuy's Avatar
Very interested... If I can fix my current problems Im having then Ill jump on this
Old May 16, 2012 | 11:22 AM
98nismomax's Avatar
If it did have the extended Rev limiter that you think it would say it on the ecu.
Old May 16, 2012 | 11:46 AM
J2FRESH's Avatar
OP lets test this sucker out on my car if it has extended limiter I may be enticed to buy locally
Or maybe someone could just call JWT and ask
Old May 16, 2012 | 01:37 PM
I'm in the Pasadena area. If you'd like to test it out, that's cool with me. It's just sitting in the office right now Drop me a PM if you're interested and we'll work something out.
Old May 22, 2012 | 03:32 PM
As mentioned in my edit in the original post, I just heard from JWT and they tell me that the ECU does have the extended rev limit. If you were holding out for that, now's your chance!
Old May 22, 2012 | 03:39 PM
What mods did you have when you ran that ECU?
Old May 22, 2012 | 03:46 PM
aackshun's Avatar
^ Just get it.
Old May 22, 2012 | 03:51 PM
Only engine mod aside from the ECU was a y-pipe. Everything else was suspension and audio.
Old May 22, 2012 | 04:45 PM
Originally Posted by aackshun
^ Just get it.
Shat up I not ready yet. Need more funds.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
