VA FS: Brand new 6MT shifter cables
I have brand new 6 speed shifter cables for sale. $95 plus shipping, US only. PM me please instead of responding to this thread because I'm probably not going to check it that often.
ok aaron, i can get 05max cables, and 6th gen bracket. ill be good to go?
edit nvm, i think you was talking about needing the whole shifter assembly .
sorry for thread jack op
Also the brackets for the transmission are slightly different between the years but actually have the same cable mounting points. I know this from first hand use as I was having issues mounting my cables for my 6 speed swap and used both.
As my post stated, I am willing to assume that L31 Altima = A34 Maxima cables.
So they're longer than 02-03 Maxima cables... By a good 5-6 inches.
I'm using L31 Altima cables in my 4th gen... They're just going a weird route in my engine bay, I should use heat wrap around them because I sent them around my headers to take up some of the extra slack in the cables, but I have not done this yet.
So if Surratt hasn't brought these yet and you're looking to 6MT swap your 4th/5th gen buy these cables and buy some heat shielding wrap.
Or you can always cut your hole in the firewall in a unique spot.
Many ways to do it, just know that these cables are on the long side (again, this is my assumption).
This was my concern with these cables.
So unless we can get confirmation that these are the SAME as 5.5 or 5-6 longer. I wont be buying them.
I didn't get precise measurements, but the longest cable (which I believe is the shift cable; it has the round circle end) is roughly 53" end to end, and the shortest cable (which I believe is the select cable; it has the plastic end) is roughly 47" end to end.
Mar 12, 2020 12:06 AM
pktaske
Sep 4, 2015 08:40 AM
