put jumper cables on backwards might of messed something up
hey guys new to the game did a stupid guy move i wasn't paying attention and i put my jumper cables on backwards what could be messed up the car turns over but wont start the battery i have is from a infinity its a lil smaller but it works
98 3.0 se
98 3.0 se
I did that once long ago on my 96....blew the fusable link. If urs is turning over its not that though. Does it turn over strong or weak? Might wanna swap out for a good battery n start there.
yea i kno i started checkin my fuses today i dont have a tester at the moment so i pulled out all of them one by one and did a visual the fusible links are fine the ones under the dash fine anything else i should check
If you replace the battery and all the fuses are okay and it still won't start, computer is probably toast. You can find one in a junk yard swap it in and try starting it up. If it still doesn't fire up you can at least rule out the ecu and return the ecu to the yard for a refund.
ok so i droped a new battery in it changed mad fuses its started up ran i took it for a ride, drove fine ran it on and off a few days, haven't started it in 3 days now it wont start, turns over smooth, what you think it could be?
pktaske
May 6, 2016 07:49 AM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
Oct 24, 2015 08:05 AM
pktaske
Sep 4, 2015 08:40 AM
