CA WANTED: VQ30DE ENGINE!! in Los Angeles CA
No luck on KC Nissan, but he did refer to California Auto Wrecking (also on Glenoaks), and the gentleman, Fred, quoted a price of $750, plus $500 installed, for my Maxima. The engine has 85k, and he has several 4th gens in stock.
Does anyone have experience with California Auto Wrecking?
try this place too
http://www.yellowbook.com/profile/g-...856930900.html
As easy as it might be to "just be done with it" and go with a 3.0L engine, it might be easier in the long run going 3.5, since it will be a much newer and fresher engine. I'm not on the site often, but I assume there might be some stickies for this procedure? Any advice on this; where to find a 3.5L and how-to's for the do-it-yourselfer, would be much appreciated.
Also, could I use my '98 automatic transmission without mods or expensive part changes? In other words, how "bolt-on" is this job, or is it?
Okay, doing a bit of research and just figured out that DEK refers to the 5th generation Maxima engine, and not the 3.5L. I assume with this engine, there's a better chance I can use my old tranny? How plug and play ready is this swap?
Thanks guys.
Thanks guys.
Most of the FWD or if not all of the Nissan FWD trannies are interchangeable with all the FWD Nissan engines. I know the tranny will bolt up fine to the DEK engine and also the 3.5 as well.
At this point, just from the feedback I'm getting here, I'm leaning heavily towards the DEK engine. If it's as simple as pulling one from any 2000 or 2001 Maxima, it seems a much less expensive option, without all the headaches.
I think I could do this one in my garage as it sounds, but the 3.5L, not sure if I could pull it off.
95-03 interchangeable although some may require additional modifications but nothing to major. I recommend staying with a DE (VQ30DE 95-99) or go to DE-K (VQ30DE-K 2000-2001) just for reliability reasons, and what not.Difference in DE and DE-K is mainly the Upper Intake Manifold System, which many who have the DE motor upgrade which is know as 00vi= 2000/01 Variable Intake. It frees up more air and thus gives more HP/TQ.
DE = 190HP
DE-K = 220HP
Thanks for that. So, a solid 4th generation tranny would be up to the task for a DEK engine, but perhaps a tad under built for a 3.5L, despite the fact it bolts on?
Go with the DEK. They should be readily available given to the number of 5th gens out there. I know for sure it is going to be ALOT easier than a VQ35 swap...
Have fun with it and just take your time and do it right the first time...
Hi again, anybody have experience with this engine seller?
C & T Japanese Engines Inc 1127 E Philadelphia St (909) 923-5588
He says they have two VQ30DE-K ('00-'01) in stock (price: $750); 65,000-80,000 miles, or thereabouts... plus, these are not from the Japanese market, but US engines.
Seems like VERY low mileage for a 12 year old engine used in the US.
Also, I see that Car-Part has a 99k DEK from Bell Auto Parts in Sun Valley for $700... any experience with Bell Auto Parts?
Thank you
Thank you
have you tried k watanabe? they are in north hollywood and thats all they do is sell engines. give them a try. ill try n drive by tomorrow and get the number. also if you run across a 5 spd in your travels im in need of one.
Im subscribing to this thread cuz I might be in the same boat soon. I have talked to C T Japanese engines befoer and they only sell engines and trannys but no installation, if that makes a difference to you.... Let us know what happens....
I thought Watanabe was out of business. If you know their number, let me know as I would appreciate it. And, I will keep my eyes open for a five speed transmission. Definitely will let you know if I find something
Anybody else with experience dealing with CT engines?
didnt drive by there yet, its pretty nearby though so ill get there. Maybe its called something else now, either way its the same kind of place ill definitely get the number and post it though
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
