92 gxe cab fans
Old May 22, 2012 | 05:33 PM
lkoroush's Avatar
92 gxe cab fans
My cabin fans don't turn on is there a fuse or relay that would cause this?
Old May 23, 2012 | 01:04 AM
maximo018's Avatar
Near your left knee on the kick panel closest to the door there are the fuses behind the cover. (just in case you are familiar with where they are "not to offend") Check the one for the blower. If not the its time to go get the trust multimeter and test the blower itself. Hopefully its just a fuse.
Old May 23, 2012 | 07:22 AM
lkoroush's Avatar
K thanks I kept over looking that fuse haha
Old May 23, 2012 | 08:09 AM
shiloh51933's Avatar
There's usually a reason that the fuse popped, kinda rare 4 the fuse to be defective. I'd check the blower motor resistor if just replacing the fuse block fuse doesn't work.
Old May 24, 2012 | 02:19 AM
maximo018's Avatar
Yeah usually its because something is grounding out. Same thing happened to me with my fog lights. Turned out it was the power cable grounding out against the metal housing.
Old May 25, 2012 | 07:58 PM
lkoroush's Avatar
It turns out someone put a 10a instead of 15a fuse
Old May 25, 2012 | 08:02 PM
lkoroush's Avatar
Let's see if that fixes the problem
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Mar 29, 2016 11:08 AM
Redfox
Sep 28, 2015 10:41 AM
