change fuel filter car dont start
Old May 26, 2012 | 12:45 PM
mariog88hh's Avatar
i change my fuel filter in my 95 maxima and now the car dont star it only cranks cranks
i disconnected the positive side of the battery after that i just took the fuel filter out put the new one in connected back the possitive to the battery and now the car just cranks cranks a friend of mine said the anti/theft alarm kick in and is not letting the car start
Old May 26, 2012 | 01:01 PM
Dave H.'s Avatar
Did you put the fuel pump fuse back in???
Old May 26, 2012 | 01:03 PM
mariog88hh's Avatar
i never took it out
Old May 26, 2012 | 02:03 PM
GGENIUS's Avatar
check the fuse son.
Old May 26, 2012 | 02:24 PM
Product_Of_Korea's Avatar
Did you put it in upside down?
Old May 26, 2012 | 02:26 PM
ShocknAwe's Avatar
I dont really understand your post but its possible you put the filter on upside down? I would imagine it might not flow so well that way or its possible you blew a fuse messing with the bat.
Old May 26, 2012 | 02:27 PM
max ride 41's Avatar
i dont even know how to reply,
Old May 26, 2012 | 02:57 PM
asand1's Avatar
Did it start before changing filter? Have you allowed time for the filter and rail to fill back up and pressurize? Key on a couple times without cranking to prime. Are you leaking anywhere?
Old May 26, 2012 | 09:12 PM
surban1's Avatar
+1 on checking for a blown fuse (or relay?) and double check filters in correctly (though this shouldn't prevent fuel from being supplied). if fuses ok, then troubleshoot as normal; ie verify getting fuel & then getting spark.
Old May 27, 2012 | 04:15 AM
wirelessdude04's Avatar
Wow a post without a pic of your car
Old May 27, 2012 | 04:17 AM
Check and measure filter is installed corrected.
Usually your suppose to take the fuel pump fuse out to relief pressure from the lines.
So your car is getting spark but not fuel correct?
Check all your hoses make sure there on tight and no pinched lines.. You could try spraying some carb cleaner or something onto your brake booster to see if it fires up.
Old May 27, 2012 | 04:19 AM
Sorry iPhone sucks with predictive text..
Spray carb cleaner into your brake booster line connected to your intake manifold
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
RealityCheck
Aug 5, 2015 06:18 AM
maxima297
Aug 3, 2015 12:50 PM
