Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
trying to adjust BC coilovers preload
Old Jun 1, 2012 | 10:22 AM
mrj7500's Avatar
Installed BC's on my i35 today and needed to adjust the ride height about a half inch in the rears and some minor adjustments in the front.
I messed up and changed the spring load on the left rear, in a rookie mistake. So then I thought I'd reset the preload.
Using this post as a reference:
http://forums.maxima.org/advanced-su...er-brands.html
I tried to turn "a" down, to take all the load off the spring. To the point that I had to lock "a" and "b" to move the collar higher. This process continued for about an hour. It seems like there is just as much load on the spring as when i started.
Should I continue the process of raising the collar, unlocking "a" and "b", and lowering "a" to release the load? I'm concerned about the tightly compressed strut boot.
Pics:
https://i.imgur.com/esREI.jpg
https://i.imgur.com/xmvE5.jpg
Seems way harder than it should be, any advice would be much appreciated!
Old Jun 1, 2012 | 01:27 PM
95maxrider's Avatar
Lightly modded
I don't fully understand what the problem is, but I will start by saying it appears as if you have pretty much maxed out your drop. Are you trying to slam your car to the ground?
It took me a minute to understand how it all goes together, but I can now reset preload and adjust ride height in a matter of minutes, so you're doing something wrong.
First I think you will need to raise the ride height up quite a bit because right now I don't think you can even adjust preload since the B ring is right on top of the C ring. So loosen C and raise it all up with A, then tighten C. Once you have about an inch between A/B and C, then you can try and set the preload according to the procedure.
Old Jun 1, 2012 | 03:07 PM
mrj7500's Avatar
Thanks for the reply!
Based on where the car sat when I put it on the ground after the installation, I think I'm going to be somewhere around 25.5", keep in mind I am on 19's. So not extremely slammed in my opinion. Thoughts?
I agree that "a" has to go up, in order for the collar to allow for additional adjustment. So that's the first step obviously. What confused me was never being able to get the load off of the spring. Maybe I just needed to keep going some more, eventually the load has to come off the spring.
They seem like a quality product, highly recommended and much needed for my worn out stock suspension. Getting them installed and set up at a baseline is what's important to me.
Old Jun 2, 2012 | 06:55 PM
wirelessdude04's Avatar
Make sure you leave those collars greased for future adjustments
Old Jun 2, 2012 | 07:02 PM
95maxrider's Avatar
Lightly modded
What specific type of grease are you talking about? I would think you would just want to keep them clean with soapy water since the grease could allow the collars to loosen.
Old Jun 2, 2012 | 07:08 PM
I mean I put wd40 around the collars and in between the collar's so they won't rust up etc for the future. The collars shouldn't loosen. I use the hammer and flat head trick to tighten them up after the spanner wrenches. They can only go so tight with them
Old Jun 5, 2012 | 11:14 AM
Matt93SE's Avatar
STFU n00b!
I've had collars work loose on my 240 several times. I don't put anything on them and am still able to get them to turn once a year when I need to make adjustments.
And WD-40 doesn't to anything after about a week. it's fish/snake oil. if you want something to last, use real antisieze or lubricant.
Old Jun 5, 2012 | 12:29 PM
mrj7500's Avatar
Everything cool now. It took a bit of figuring out. Preload was set at 4mm (the thickness of the spanner wrench). Height is at 25.5" all around and set a baseline of 16 on the soft/hard dial. It's not overly rough at all, very forgiving for being that low IMO. Loving them so far!
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
