Sponsored by:
Sponsored by: CARiD
DEK/VQ35 Hybrid Setup Qs
Old Jun 25, 2012 | 09:21 AM
MoncefA33's Avatar
Okay so this week I will be performing the following.
My DEK ported/polished/valvejobbed heads on top of a mildly built VQ35 block, using the following bits:
  • S1 knockoff cams/HR valvetrain
  • ARP headstuds (VQ35DE)
  • 3.0 timing/ECU
  • SSIM portmatched, NWP spacers, PFTB, 82mm MAF (for now)
Questions:
Anything else I should look out for that are specific to this type of build?
Approx compression ratio?
What kind of AFR/timing #s should be shooting for?
The other typical 3.5 swap will be taken care of, but if anyone else has any tips I will be glad to listen to them.
Old Jun 25, 2012 | 11:43 AM
McSteve's Avatar
rev-up oil pump and rod bolts?
Interesting change of mind.... a couple months ago you were hating on the 3.5 swap
Old Jun 25, 2012 | 11:51 AM
MoncefA33's Avatar
Got both of them.
And I wanted to try it.
Old Jul 22, 2012 | 09:55 AM
MoncefA33's Avatar
Question:
I'm not able to fit the VQ35 LIM/UIM on this setup, because the plenum is hitting the coilpacks. It barely clears the rear valve cover (5th gen).
What valve cover should I be using so I can put my SSIM on there?
Old Jul 22, 2012 | 02:51 PM
MaxPR0908's Avatar
You have to use your IM in order to use the 3.0l valve covers.
Old Jul 22, 2012 | 09:50 PM
shrek's Avatar
you need to use VQ35 rear valve cover and coil packs,might as well do the front one
Old Jul 22, 2012 | 10:26 PM
mightyMax95's Avatar
Doo eet! Working coilpacks ftw! lol
Old Jul 29, 2012 | 08:46 PM
MoncefA33's Avatar
Won't this cause leaks though?
Old Aug 4, 2012 | 07:51 PM
CPBOYZ's Avatar
Hi compression like 12.5-1 my boy here has it done get alot of tq motor made for nos....but my bro with 30 timing 35 swap pulls him every time
Old Aug 27, 2012 | 11:22 AM
MaxiNone's Avatar
whats your power goals?
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
