RPF1's +38 offset
Old Jul 2, 2012 | 11:03 AM
machete's Avatar
RPF1's +38 offset
As of now the car is sitting on XXR 521's 18x10R, 18x8.5F +25 all around and Im loving the flush look.Will the new set up(18X9.5 all around +38 offset)look good?Anyone running +38?Does the wheel seat close to lip of the fender or they stay tucked in?Any pics you can post will be appreciated.I'll be running 225/40/18 on all 4 wheels and have already considered getting some 10mm spacers in case I don't like the fitment.Another question,I have never run a set up spacers before so will I need extended studs if I was to run a 10mm spacer?
Thanks in advance.
Old Jul 2, 2012 | 11:06 AM
Amerikaner83's Avatar
iirc, a HIGHER offset = closer into the center of car. i.e 40 offset sits further out than a 45 does.
YOur rears will be more sunken in than they currently are, if I did my math right.
Old Jul 2, 2012 | 11:10 AM
phatboislim's Avatar
if i'm thinkinf right those are going to barely be flush. if you run spacers, some come w/ studs...i think w/ studs it starts w/ 15mm spacer...i'm 99% sure you are going to want to look at extended studs though
Old Jul 2, 2012 | 11:14 AM
machete's Avatar
That I know, Im just trying to know how sunken will they be.
Old Jul 2, 2012 | 11:17 AM
think about it like this...25mm = 1"...there is a 13mm difference off top w/ the offset of all wheels, that's just over 1/2" difference of how much it'll sink in, then take into consideration you are going smaller in width by 1/2"...so the rear wheel as it sits now, subtract roughly an inch of it sitting in, that should give you a good idea of where your wheel will be sitting
Old Jul 2, 2012 | 11:28 AM
machete's Avatar
1" does not sound bad in paper lets see what it actually looks like when they'r on.Thank you for the input.
Old Jul 2, 2012 | 11:33 AM
no problem and it's actually 25.4mm = 1" but...GL
Old Jul 2, 2012 | 04:23 PM
joecurr's Avatar
Looking strictly at the wheel widths and offsets, according to http://www.1010tires.com/WheelOffsetCalculator.asp, the 9.5" +38 wheels will sit 19mm IN compared to the 10" +25 and the same compared to the 8.5" +25. So you might want to go with a 15 or 20mm spacer for the rear if you want it to look similar to your old setup.
Old Jul 3, 2012 | 08:02 AM
machete's Avatar
Already got it figured out,after test fitting the wheels I've decided to go with 5mm spacers for the front and 10mm for the rear.
Old Jul 3, 2012 | 01:27 PM
03VQMAX's Avatar
You should go 15mm spacers all around.
Old Jul 3, 2012 | 01:51 PM
machete's Avatar
Im trying not to change my studs.
Old Jul 3, 2012 | 01:55 PM
IIRC 15mm spacers come w/ studs when you bolt on the spacer...
Old Jul 4, 2012 | 09:31 AM
03VQMAX's Avatar
15mm+ should be bolt ons
Old Jul 5, 2012 | 10:06 AM
joecurr's Avatar
It appears H&R has 15mm bolt-on spacers (DRM series), but he'd have to make sure his wheels have the clearance next to the lug holes behind the wheel for the OEM studs because they'll be sticking out.
And with 10mm spacers you'll need extended studs.
Old Jul 16, 2012 | 01:19 PM
machete's Avatar
No spacers for the rear,will run a 15mm offset wheel.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
