PA fs/ft custom det turbo setup with 3inch dp
So I was holding on to this setup encase I ever bought another maxima but I recently went for a ride in a gtr with tp and exhaust and no longer have any desire. So with that said my turbo setup is for sale, it's based on the jdm det setup. The setup has wrap around headers, no egr, t4 flange, 44mm wg flange, full 3inch vband dp that runs under the oil pan. Everything is sprayed with ceramic paint from pepboys and baked and the 1st part of the dp and cover over pipe is heat wrapped. Not sure is this will clear a 5.5 or 6gen starter but I do know the shifter bracket will need to be modded
I am looking to get 700.00 for the setup and will accept trades. I need two 38mm wg's, intercooler, 2.5, 2.25 and 2inch ss pipes and bends, couplers, 440 or 600cc topfeed injectors, 50mm bov
just to clarify, this is the dp, headers, and turbo? and it would appear it's set up on a DE-k motor... (doesnt make a difference DE or DE-k, but you said based on the DET so wanted to make sure it wasnt setup via their manifold...)
Has this ever been run or was it simply fitted and garage kept? Condition on turbo? Power put down if it was run?
this will work on a de or dek
no it has never been used
Was bored so I bolted up a 6spd trans to this setup and it fits with a 4gen starter. The problem is the niod on a 4gen points down and I'm not sure of the 5.5 or 6gen starter niod is in the same location or points up. If it points up the niod does not clear the crossover pipe and it would need to be modded
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
