Front bearing / hub problem
Old Jul 16, 2012 | 09:41 AM
WielkiWaac's Avatar
MaximaDriver
Hello All.
I need to replace my front wheel bearing. Car was making noise when driving plus there is a play on wheel when car is on lift. Now, when I replace bearing should I replace hub as well? I dont have to much $$$ right now and dont want to buy new hub if old one is still in good condition (which I dont find out till everything is seperated).
Old Jul 16, 2012 | 09:58 AM
Quickywd01's Avatar
Czesc, you can re-use the hub but the bearing is pressed into it so either you have to do it or take it apart and take the hub and bearing assembly to a shop to press out the old bearing and press in the new bearing.
Old Jul 16, 2012 | 10:41 AM
WielkiWaac's Avatar
MaximaDriver
What brand would you recommend?
Old Jul 16, 2012 | 11:57 AM
asand1's Avatar
I have seen wheel bearings on a Jetta so bad the hub was worn to the point of the bearing races being loose on the hub. You might order one locally in case you need it. If not, just dont go buy it.
Old Jul 16, 2012 | 12:40 PM
VisciousMo's Avatar
I would replace the hub.
Old Jul 16, 2012 | 12:52 PM
aackshun's Avatar
National Brand bearings = OEM supplier for many manufacturers, not sure for Nissan though.
Old Jul 16, 2012 | 01:40 PM
mrjamaica98mx's Avatar
just had mine replaced mechanic said when he take it off it fell aprt in is hand i would replace the whole thing.
Old Jul 16, 2012 | 05:05 PM
nismomaxgtr18's Avatar
Just replace the hubs along with the wheel bearings. You can get OEM ones from nissanpartsasap.com.
HOKUSMAX
Nov 13, 2017 04:34 AM
boomerbrian
Nov 8, 2015 05:10 PM
homeyclaus
Sep 3, 2015 06:15 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
