Weirdest No Start Ever... Please Help
A friend of mine blew his headgasket and decided to get a new engine so I decided I would do him a favor and replace the engine for him. I have done 4 maxima engine swaps in the past time consuming but otherwise pretty straightforward.
This has been this headache of all of them. The actual swap went off without a hitch the engine came out fairly easy and the new one went in fairly easy. The engine started up on the second crank no problem.
So i proceeded to finish tightening everything up engine starting no problem at least 4 times along the way. I even had my friend drive the car around a little cul de sac across from my house just to make sure everything was ok.
Right after this we put the hood on and the rest of the air intake and bam car refused to start up.
It cranks the engine turns just no start. I've checked the basics I have fuel and no intake leaks however I have no spark on cylinders 2,4,5 and it is intermittent on cylinder one. I have checked both crank sensors and the cam sensor and replaced all with known good ones from my own car, no change.
Also per the fsm I checked for the proper voltages from the ecu and shorts to ground to the sensors everything is within spec except when I test the crank sensor near the flywheel using the screwdriver test I only get 3.x volts instead of five but car is still missing lots of spark.
The only other thing of concern is as we were trying to start the engine as all of this was happening the starter somehow worked is way loose and made a god awful noise. But we retightened it and no other noises, I also checked the flywheel to make sure none of the timing gear teeth were missing, chipped etc. Also performed a leak down test to try and determine if the engine jumped timing. All cylinders reading similar leakage in the green.
I am about ready to grow some hair so I can pull it out please help!
I remember seeing that before throughout the forum, but I think that when that is an issue the car does not crank at all and this engine started up several times before it just stopped starting out of the blue
If im not mistaken, the negative battery cable connects to the transmission, and the engine is then grounded through the tranny. With a poor ground between the trans/engine, the starter will spin good, but there be too much of a voltage drop between the engine and trans. This will cause a poor signal to the injectors and sensors during cranking.
If the timing chain is off one tooth, the car won't start and you will not have spark on some cylinders. Cylinder 2 and 4 seem to be very common from what I have read.
But the car would probably never have started in the first place, unless the chain is extremely loose and jumped position after you ran it.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
