How do i hook up a scanner to the stock alarm
I have a 95 max
how do i hook up the scanner to my alarm so i can activate it with the remote when i lock the doors
Scanner - Lil mounting tha has a red led light tha supposed to b a theft deterrent
currently i have it hooked up with a switch to the battery..
stock alarm huh? Ok here's one way. You can hook up the positive to a constant hot. connect the negative to the ignition wire of your car.How it works: When your car is turned on, the scanner will turn off. Take the keys out, and scanner turns on.
Unless there's a negative when armed wire on the stock alarm, that's the way I would do it. I did that to my sister's truck but just used a LED.
Have fun
Have fun
Wouldn't this eventually run down the battery? I know LED's don't take much from the battery, but if it is going constantly when the car is off, this would be something I would worry about.
Unless he drives the car out of town once a week or so to charge the battery, it will eventually go dead earlier than normal. And is the scanner thing actually LED? That would make a big difference also.
[Edited by Adidas_Boy on 11-11-2000 at 04:07 AM]
Sorry about getting off topic, it was just something that was borhering me. . . If I were you I would try and figure out a way to hook it up to the security light on the inside of the car. Since this is only blinking when the security system is armed, it would probably be the best way to do it. Although since it is on the inside, you would have to go through the fire wall and such, and it might be more trouble than it is worth. You would also have to design some sort of switch for it.
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
