I RAN A 14.2 WITH 3 BOLT ON AND 9 TROUBLED CODES
I said it before and i'll say it again, maxima's are badass cars. I decided to take my car to the track to see what it can do and I was very proud.
Even though I had 9 troubled codes and only have a CAI, headers, and a lightweight crank pulley she ran 14.2 in 29 degrees last wednesday. This is a major accomplishment for me because a few months when I started I could only do 15.5 stock and inexperienced.
I'm actually getting better because I managed to get a 2.1 on my 60'
Now if I can get rid of those codes, lighten my load a little and get a cooler day i'm sure I can run high 13's
The only mechanical bolt on performance mod on the car right now is the CAI, headers/exhaust, and the light weight crank pulley. I didn't include the BOP because it's just a plate and you can't get any noticeable gains without the spacers. The codes on the other hand is what's probably hindering the max potential. I am confident if I get the dangerous codes off and race on a cool day with my spacers re-installed I might just hit that high 13's
Slicks are the biggest helper on these runs that you did. But BOP is beneficial without spacers. Especially on a drag run, your rpm aren't dropping in the area were bop gives small loss of hp/tq. PLus with you being on slicks you might have launched out of the loss range also.
P1276 seems like o2 sensor harness codes, probably doesnt affect performance much at WOT seeing as though the car doesnt use the o2 sensors to monitor AFR's anymore but may affect MPG for regular daily driving...
then again there is a few that i can see messes with performance... get em fix and enjoy a new PB again
"Bolt ons". I wouldn't say tires are bolt on performance mods, it just allows you to launch at a higher rpm with minimal wheel spin. It's aguable. You could probably achieve the same results by learning and understanding you clutch and power the car produces. I just haven't had that much experience, wanted the max results early.
Why I said it's aguable it's because I ran a 14.6 with street tires and a few of my runs I ran as low as 14.9 so it's all comes up to your skill level.
I've been doing everything to get the dangerous codes off doing everything my mechanic tells me from disconnecting the G-force fuel saver chip, replaced the MAF sensor, replace the MAF connector, both feul ratio sensors, and removes my spacers and all 9 codes come back. I been to the mechanic several times trying to figure out the codes to the point where I'm tired and he's refusing to work on my car for free.
He basically said he's not gonna do anything on the car again so I'm on my own until I get money to take it to another mechanic to see it he can figure it out.
7 codes really, getting rid of one of some of those codes gets rid of multiple lol
DTC P1283 A/F SENSOR S1 B2 <-- Sensor heater
DTC P1278 A/F SENSOR S1 B2 <-- response time/heater, harness
DTC P1148 CLOSED LOOP CONTROL <--Because O2 sensor codes
DTC P1279 A/F SENSOR S1 B1 <-- response time/heater, harness
DTC P1276 A/F SENSOR S1 B1 <-- High voltage, harness.
DTC P0400 EGR FUNCTION <- Doesn't affect power, remove it maybe.
DTC P0430 THREE WAY CATALYST FUNCTION <-- Because you don't have any catalysts with the headers.
I agree.
I agree.
I agree.
I have the 5.5 gen equivalent, no primary O2 sensors connected and all associated codes with that situation and my dyno didn't complain.
Does your track close for the winter? If it does, get there at the latest date and run, preferably later in the evening, or, watch the weather and head out on a cool day.
My track closes in November so hopefully I can sneak a run in and see what this little guy is capable of.
Never weighed the car nor got it dyno'd. Don't even know who does it. I ran 14.2 with 17" rims and drag radials in the spring 12 degrees celcius and ran the same time with 18"" rims and slicks in the summer. But I'm sure if I can run this time in 28 degrees celcius weather with codes I can run high 13's in the fall when it's cooler. Gonna put back on my spacers too...
Don't know who that is and what car he drives. I don't know any stock 6thgen maxima's other than krazy6 who broke the 13 second barrier with a stock motor. Since racing I've learn there's more to racing than having a fast car. Temperature, DA, preperation, skill, experience, track conditions, etc... So I can't really say why that's all I'm doing but it's pretty good for a 6thgen max with lambo door hinges, full interior, a rear bodykit bumper, and only been to the track about 7 times.
As for those codes that's a whole next story. I changed everything that affiliates with those codes, cleared them to see everyone come right back. I know about the codes that won't affect the engines performance, but it's that fuel consumption code that gets to me because it guzzles gas and I can't get it off. So until I can save some money to take it to another mechanic to get a 2nd opinion because the mechanic who did the engine swap basically kicked me under the bus so until then I'm driving it.
UMMMMMMMMMMMMMMMMMMMMMMM he did post in your thread
Seriously???... i ran 13.7 as an auto on stock motor... did you ever even search enough to find that out?... the 13's barrier have been broken on multiple occasions bro, not if you said not many broke the 12's barrier on motor then cool... werent you on radials???, people have been breaking 13's on street tires with these 3.5's for quite some time now lol... your tires and exhaust and i think people can break 13's given a decent temp...
We live in different countries, we run at different tracks, we have different cars, and our skills and knowledge about racing is totally different. So there's no need to compare who's success, giving advice would be greatly appreciated....
Raced a 13.7 civic
Track really sucked today because they started 35mins late, over 50 cars, and someone busted their rear axle spilling oil that took well over an hour for the clean up crew. Only ran one more race and called it a wrap. After I swapped out my wheels another spill leaving one lane closed with well over 50 cars. It wasn't my night at all...
bryants95max
Oct 2, 2015 12:52 PM
220k+ A32
Sep 23, 2015 03:38 PM
