Exedy stage 1 clutch installed, now no clutch pedal resistance?
Old Aug 9, 2012 | 02:19 PM
Maximeltman's Avatar
And I didn't even open the clutch line so all the fluid is still the same as when it was before the clutch change...
I compared the old pressure plate to the new pressure plate, and the spring loaded levers seem to be less protruding on this new clutch pressure plate than on the old one, is this supposed to be like this?
old:
new:
Can you see how on the old pressure plate, the spring levers are more aggressively pointed outward and on the new they less aggressive? Can this be a bad pressure plate?
Old Aug 9, 2012 | 09:00 PM
JNCoRacer's Avatar
Just the tip.
You got the throw out bearing on there right?
Old Aug 9, 2012 | 09:35 PM
Yea...at first I thought it fell off, but when I pulled it back apart, to my suprize it was still there. I'm puzzled..
Old Aug 10, 2012 | 12:24 PM
MaximaSpd85's Avatar
Is the fork positioned properly on the pivot? And not cracked?
Old Aug 10, 2012 | 02:16 PM
Yea, fork is good, positioned correctly and not cracked. I think the pp is faulty?
Old Aug 10, 2012 | 03:17 PM
this is kinda frustrating because its holdn me back from finishing this...this is a vq35 block but that doesnt matter?
Old Aug 10, 2012 | 04:18 PM
No when you say no resistance... Do you mean it goes to the floor and doesnt come back up? Or its just really soft? Did you start the car and shift through the gears when u had it all together?
Old Aug 10, 2012 | 05:15 PM
Just at the end of the pedal throw there's a very little bit of resistance, like the slave cyl piston is almost all the way out before resistance happens. Then it stays there and won't come back up.
Old Aug 12, 2012 | 05:45 AM
ok I got it! thanks!
Old Aug 12, 2012 | 09:19 AM
What was it?
Old Aug 12, 2012 | 09:53 AM
Crusher103's Avatar
bad slave cylinder. Usually when you replace that and your master magically goes bad aswell, its annoying but thats what happens.
Old Aug 12, 2012 | 10:40 AM
Nope
It was the fact that I installed the throwout fork retaining spring incorrectly the first time like a rook.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
