NC Voxx 16x7 wheels, '96 tails, 300zx & maxima rotors
I have a set of four Voxx Legra wheels, 16x7 with a 40 offset. These are a nice set of wheels with a low weight, they have no dings, dents, or bends.
I switched these out for a new set that would clear my new brake set up, so consequently if you have a Z32 caliper on the front these will NOT clear, even with a 5mm spacer.
they look very good and I'm only asking $200 for the set. I will ship if you want but the shipping cost is separate.
I also have a set of stock '96 tails in great shape, no cracks or discoloration. The right outer light will need a new backing plate with the wiring as I raped it for a fix on the '98 set I picked up, it's an easy part to come by and even more so if you have a current set, you can just swap it over.
I don't expect to get much for these, so let's say $20 for the whole set, you pay shipping.
I have some front rotors from a 300ZX that have already been trimmed down around the outer edge so that they will fit the Z32 caliper when you mount the calipers in the Maxima's "stock" location.
I never used these because after finding they would not fit the above wheel and i knew that I had to buy new wheels, I decided to change over to a 12.6" rotor instead. They are slotted and dimpled.
These are used rotors but in good enough shape to carry you for a while with no problem, but since they are used I only want $30 for them since that won't even cover the "milling" fee for them to be trimmed down.
I also have a set of rear rotors that are ready to go, they have some life left in 'em, I decided to change the rears over to a 12.3" bbk on the rear to balance out the front and didn't need these. These are crossdrilled and slotted. I only want $20 for these.
Shipping is paid by the buyer. Rotors are not light by any means, so take that into consideration.
If you have any questions send me a PM or E-mail.
Thanks for checking out my ad.
Yes, they will fit, bolt pattern is the same but I always recommend using centering rings. They cost about $5-$8 at Discount tire and you would need a 73mm (wheel bore) to 64mm (hub size for your Acura).
They will fit your car, this size is listed as a "Plus one" on Discount Tire's website, basically meaning you have a 15" stock and a 16" wheel is "one" size larger and they show these wheels fitting that car.
Let me know if you have any other questions.
Usually these are cheaper to ship if two wheels are boxed and taped together to form one big box rather than shipping each one seperately. I'll check with Discount up the road and see if they have some wheel boxes they don't need that I can use for shipping.
that's fine
That's fine, if the price is right I'll take them from you, sometimes shipping is to expensive hopefully you can find a good deal, thanks
That's for a 18x18x18 box (two wheel boxes taped together) at 35lbs combined (2 boxes/2 wheels/packing materials) shipped to you.
So that would be $30x2 boxes (4 wheels and boxes)=$60 total to ship....not as bad as I was thinking.
But we'll just call it $250 shipped to you and if they go out by thursday you would have them by Saturday or Monday at the latest.
Thanks,
Tom
cool!!
It didn't seem to matter if I shipped them through UPS Ground or USPS Priority, they both came out at $30 a box to ship.
Thanks,
Tom
Thanks,
Tom
PM me your paypal and I will pay you right away, thanks
03VQMAX
Sep 25, 2015 04:19 PM
Team STILLEN
Aug 10, 2015 04:29 PM
RealityCheck
Aug 5, 2015 06:18 AM
Thank You!
