Timing belt tensioner broke, valves are bent
Hello All, Last monday I was driving my maxima when I start hearing a knocking sound, didn't know what it was, so I pulled over to check under the hood, but can't tell anything weird, so I start the car again the noise continue, since I was like 1/2 mile from home I drove it back, when I called the mechanic he inspect it and told me the timing belt tensioner was broken and chances were I probably damage some valves if I drove it like that. but he won't know until he replace the tensioner.
After replacing the tensioner, confirmed the worst, engine is making that sputtering noise and I was told by the mechanic my valves are damaged, he quoted a $850 job with parts and labor.
My question is, is it worth doing a repair on the valves, or should I go with a engine replacement? I replaced my engine with a JDM before for a gasket problem and was running great before this happened. If the valve job is done properly, should it work just as good as it was before, what is your experience on this kind of problems.
Thank you all for your input.
Originally Posted by shiloh51933
$850 isn't too bad and doing the valve job will be cheaper than swapping in another used motor. Unless you know for sure the used motor is in good running condition I would repair what you have.
tsi6001
Oct 3, 2022 10:23 PM
Ray229Harris
Sep 16, 2015 08:16 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
