New kicks for "BuTTa"
Are you lowered? Definitely need some lower-age on the 3rd gen with aftermarket wheels. Kind of looks silly otherwise IMO with all the massive fender gap.
And is your car white or the cream color?
[QUOTE=James92SE;8660762]Are you lowered? Definitely need some lower-age on the 3rd gen with aftermarket wheels. Kind of looks silly otherwise IMO with all the massive fender gap.
And is your car white or the cream color?[/QUO
They're not black... more of a Hyper-silver
Yes, I'm dropping her w/Ksports 2" drop; yes, she's Butter cream. (pearl white)
May even paint 'em when I put the body kit on her; everything same color as car.
i dont know if that would work, i was lowered 2.5"/2.0" and on stock rims with 205/65/15's the front tires went into the fender
right before the car blew up i got a set of Rays TE-37 and put 235/45/17's on them. never got to run them because i couldnt get the right wheel spacers for the rear, but even with a test fit on the fronts it was a pretty tight fit
Picked up wheels today; the colour is better than it appeared; more of an dark gunmetal metallic gray,that picks up the pearl coat almost perfect. cant wait to get'em mounted, but I guess I'll have to need tires.
I guess I'll find out tomorrow, if not they may have be bored. I thought I already did the research on these and we could use 35-40mm, no?
Nissan hub bore is 66.1, make sure you are not confusing the Hub bore for the Offset. Im not sure of the exact offset for a 3rd gen but anywere from +50 to +25 with most reasonably width wheels will fit. The lower the offset the better it will look.
Offset should be from 35-40mm, from the searching I've been doing.
Yeah, you're right they are 66.1mm, that was an old post whereas I was trying to get some Borbet wheels to fit a couple of years ago. Well of course they didn't work so I went with these ones. As It turns out I like the Drag wheels better.
mclasser
Sep 24, 2015 11:57 PM
still a good price tho enjoy em
