WA FS: Shortened Konis on H&Rs, Wilwood 12.2" brake kit
Hello
I have decided to reduce my vehicles and my Maxima is one of them on the list. So here are some parts that I have taken off as I start returning to stock.
Up for sale are already modified, just bolt up and go set of Koni adjustables with H&R springs. I have the H&R rear springs on the upper perch of the shock body, so you will not have the saggy rear end syndrome.
Front and rear have been shortened as pictured. The rear have been shortened by the use of aftermarket rear shock mounts for a P11 G20 I bought on G20.net. Almost all parts are new, including new bellows. If I remember correctly, I have also shortened the bump stops a bit. I have the Front/Rear adjusted in the middle, 2.5 turns on the front and 2 turns on the rear.
One problem...One rear shock mount has a damaged stud
(in pic). I've tried to "repair" by running a tap on it, but it isnt perfect. I've driven it like this without any knocking or odd noises.
This is a great riding set up with a modest drop! I spent a lot of time researching and getting these put together. I've only driven about 1500 miles on this, so they are basically new.
(Updated Pricing, 2/14)
Looking for $650 shipped to the lower 48 for the set.
Wilwood 12.2" brakes. This was put together by Brian at Fast Brakes. The pads are Hawks. The kit will include all hardware necessary to installation. This also was used only for 1500 miles. They were installed at the same time as the Konis.
They are made to fit 16" wheels radially. With 17x7.5 CE28Ns, I needed +33 to clear the calipers as the calipers are huge.
Updated
Looking for $650 shipped to the lower 48.
All as basically new parts, just bolt in and go. I did all the hard parts
Pics - Wilwood
http://i265.photobucket.com/albums/i...Kit/Rotors.jpg
http://i265.photobucket.com/albums/i...pads-rotor.jpg
http://i265.photobucket.com/albums/i...it/Caliper.jpg
Pics - Koni
http://i265.photobucket.com/albums/i...ifiedKonis.jpg
http://i265.photobucket.com/albums/i.../KoniLabel.jpg
http://i265.photobucket.com/albums/i...is/HRLabel.jpg
http://i265.photobucket.com/albums/i...Konifronts.jpg
http://i265.photobucket.com/albums/i.../StrutTops.jpg
Updated
Pics - Wilwood
Pics - Koni
Glws but just an fyi.. most people use oem bbk setups... i sold my wilwood 12.6" setup for 450ish shipped...mine wasnt as clean but its hard to resell a wilwood kit consiering most people use oem bbks now...
You can get the rotors from fastbrakes.com for one. From info I got from fastbrakes, anyone that carries wilwood 2 piece rotors in this size (12.19") will have the replacement rotor.
I believe they are tacked on. I'd have to look, but I am sure they at least pressed in as I would have changed the bolt out other wise. But in retrospect I should have just ground off the tack weld and put a new one on.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
