VA 3.0 parts for 3.5 swap
Old Dec 1, 2012 | 02:54 PM
cardana24's Avatar
Blown
Hey guys, I just took apart a vq30 and would like to sell the parts that you need for the vq35 swap as a kit. I think I am including everything you would need to take off of a vq30 in order to do the swap. If I am missing something please let me know because I still have the rest of the engine. This will allow you to continue to drive your car with the stock engine until you can get your 3.5 put together. Rather than having to have your car down the whole time in order to take your engine out. I have pictured what is included. Crank pulley and bolt, timing chains, with the guides, cam sprockets, crank sprocket, upper and lower oil pans, inner and outer timing chain covers, left and right cam journals (don't remember if you need these but they are included), coolant log along with water pipes that go around to the front of the engine, all of the bolts for; the timing chain covers, oil pans, cams, crank. I am asking $200 shipped for everything. None of the parts are broken, and are in good used condition.
Old Dec 1, 2012 | 03:21 PM
deloa84's Avatar
Just an FYI, you will need to throw in the water pump from a 3.0 as well since the 3.5 water pump does not line up to the 3.0 chain sprockets...
GLWS
Old Dec 1, 2012 | 04:38 PM
cardana24's Avatar
Blown
GLWS
Gotcha, I knew that, but thanks for the heads up. I am not including things that IMO, should not be reused (i.e. water pump, tensioners)
Old Dec 2, 2012 | 05:40 PM
cardana24's Avatar
Blown
I also have both of the block plugs from either head on the vq30. These are useful if you don't want to run the 3.5 oil cooler (often times they come damage if you are buying junkyard engine).
Old Dec 4, 2012 | 08:04 PM
Juancho's Avatar
So if i was going to swap my 3.0 for a 3.5 , i will need all of these parts???
Old Dec 4, 2012 | 08:39 PM
Fakie J Farkerton's Avatar
Yes.
Old Dec 5, 2012 | 05:07 AM
Maximeltman's Avatar
Iwas gonna do this also, but You beat me to the punch! GLWS!
Old Dec 5, 2012 | 09:21 AM
cardana24's Avatar
Blown
Yes. If you want them let me know.
Originally Posted by Fakie J Farkerton
Yes.
thanks
Old Dec 6, 2012 | 11:32 AM
thanks
Do what I can.
Old Dec 10, 2012 | 08:15 AM
cardana24's Avatar
Blown
bump
Old Dec 17, 2012 | 09:53 AM
cardana24's Avatar
Blown
bump............I am willing to do this much cheaper if you can pick it up. Shipping is going to cost quite a bit and it's a pain. I'm in central va, I will be traveling to north/central NC in two weeks and can bring it with me if I have a comitted buyer.
Old Dec 20, 2012 | 12:23 AM
greenspeed's Avatar
How much to drop off in Richmond
Old Dec 20, 2012 | 06:20 AM
cardana24's Avatar
Blown
I sent you a PM, let me know.
Old Jan 1, 2013 | 07:36 PM
cardana24's Avatar
Blown
bump, make an offer, this stuff is in my way
Old Jan 30, 2013 | 06:37 AM
cardana24's Avatar
Blown
sold
schmellyfart
Sep 25, 2015 04:47 PM
FlaMark
25
Aug 28, 2015 10:15 AM
95naSTA
Aug 16, 2015 05:03 PM
Blackwind
Aug 5, 2015 06:35 PM
