Damn interior lights don't work anymore
Sorry lol I really didn't think it was that bad at all. But negative on all your suggestion. Everything seem ok but when I took the power cable from the headunit and connect it together with the black n red strip cable ( interior lighting wire) the dash come on but when I turn on the headlights the dash lights go off.
There are 2 black/red stripe wires in the radio connectors. One is for the dash lights, the other for a speaker. What is the signal name of the radio wire you connected to the black/red stripe wire. Are you splicing wires directly to the nissan wire harness or do you have an adapter such as a Metra kit?
Its my fault. Because I was inpatient to install my headunit I decided not to wait to buy the harness for the radio and cut the factory harness and just tap in all the lines. It dorked but it was a mess. That's when everything started to go wrong, I found the factory plug at a junkyard , so I repair it back. But still having the no dash light problem
That is smart thinking. I'll start all over by disconnecting all wires. And fix the dash lights, then I'll start to connect wires one by one.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
