Drop the engine or no?
Old Dec 5, 2012 | 05:00 PM
bkies's Avatar
I have several things that i need to replace and fix and my 96 maxima. I am going to replace the radiator the EGR valve the knock sensor, coil packs, plugs, and the rear valve cover gasket. I know its a lot of work and my question is; would it be easier to drop the entire engine out of the car to replace this stuff or just work on it with the engine in the car. I will be working at a shop and have everything i will need just needing some opinions on this.
Old Dec 5, 2012 | 05:07 PM
tosheto's Avatar
Not worth it I think. I have done all those things you have mentioned and it will not be that hard or take as long as taking the engine out. You said you will do it at a shop and that will make your job easier. Plus you can do half of the repairs one day and the rest another day. If you pull the motor the car will not be running.
Old Dec 5, 2012 | 05:34 PM
Max139617's Avatar
As for the radiator,knock,coilpacks and plugs you DO NOT need to drop the engine. I don't know about the egr and the rear gasket.
Old Dec 5, 2012 | 05:38 PM
Nealoc187's Avatar
SLOW
for those simple things no way would i drop the engine.
Old Dec 5, 2012 | 05:42 PM
nsnrider's Avatar
+1
All that work can be done under 3 hours time, tops.
maxinout93's Avatar
no all those things can be done with the engine in the car
Old Dec 5, 2012 | 05:50 PM
EvoTillIDie's Avatar
No way....save yourself the time & hassle...keep the engine in
Old Dec 7, 2012 | 07:52 PM
Snypa's Avatar
not worth dropping. all those things are very much accessible.
Old Dec 7, 2012 | 07:59 PM
Trini Boom's Avatar
You want to drop an engine for these little things?? Why couldn't we access a shop to do things like the RMS and Rear timing cover o-rings??....
Old Dec 8, 2012 | 05:07 PM
Max streets's Avatar
3.5swap then drop it other than that no.
Old Dec 8, 2012 | 07:06 PM
maxfever1987's Avatar
Keep the engine in and do everything you need done, once the uim if of everything else in easily accessible
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
jfl330
Sep 4, 2015 01:44 PM
