98 maxima shuts off at 2500 rpm
Hi my car at 2000 2500 rpm shudders then shuts off. I was told could be a vaccum leak in one of the hoses and to check them. I searched and found a hanging hose but I cannot find where it goes. I have attached pics of hose and being that I'm no mechanic so I'm lost. If any one can tell me where it goes or any solution it will be greatly appreciated.
After letting the car warm up the initial problem of engine shudder at 2500 rpm returned....the issue seems to be when the car completely warms up .....any further advice would be appreciated Thanks
I also thought that the MAF was to culprit...Another possibility:
If you havenīt replaced the Coolant temperature Sensor (Not sure if thatīs the right name) in a while, do so...Itīs not expensive and itīs a good maintenance practice even if thatīs not the root cause of your problem. However, just FYI, the CTS does communicate to the ECU and it is able to affect driveability when failing. Hope that you get your car fixed man!
Can this part be replaced by me or do i have to go to a mechanic shop??
It is pretty easy, you just need a 17 mm (I don't remember the size), it is easy accesible by just removing the snorkel and the intake bits (The black intake tubing).
It's just a matter of disconnect & unscrew the bad one and screw the new one, and connect it.
Hondarydr
Dec 30, 2024 06:15 PM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
