Another turbo 4.5gen
Old Jan 1, 2013 | 08:40 PM
t6378tp's Avatar
Turbo 3.5
Made this for myself but it ended up on someone else's car, SMDH
started off with this pile of parts
chopped and flipped some 350z ebay headers, had to enlarge all the flanges holes as they did not line up
Old Jan 1, 2013 | 08:44 PM
t6378tp's Avatar
Turbo 3.5
rear header mocked up
front header mocked up
Old Jan 1, 2013 | 08:46 PM
t6378tp's Avatar
Turbo 3.5
starting on the crossover pipe
finishing up
another view
Old Jan 1, 2013 | 08:50 PM
t6378tp's Avatar
Turbo 3.5
starting on the downpipe, it will run under the oil pan and exit the stock location so there is no ground clearance issues
sleeved flexpipe so not worries about it collapsing
Old Jan 1, 2013 | 08:59 PM
Shift_Max's Avatar
Very similar to my set-up. Looks nice.
Old Jan 1, 2013 | 09:28 PM
t6378tp's Avatar
Turbo 3.5
thanks, your car was the reason I made it
Old Jan 2, 2013 | 01:57 PM
Quickywd01's Avatar
Don't know if to stare at the turbo or the twisted headers.
Old Jan 2, 2013 | 06:55 PM
t6378tp's Avatar
Turbo 3.5
test fitted on the car just encase seeing how our setups are alittle different but it was fine
Old Jan 2, 2013 | 07:04 PM
95naSTA's Avatar
Nice job. The flipped 350 Z headers look good in there.
Old Jan 3, 2013 | 12:51 PM
Quickywd01's Avatar
Best setup I've seen so far.
Old Jan 6, 2013 | 12:04 AM
t6378tp's Avatar
Turbo 3.5
wastegate mounted
Old Jan 6, 2013 | 08:16 AM
Kevlo911's Avatar
Kevlo for President
sweet, i used to remember wanted to use Z headers for a turbo.
how many other people are using it?
Old Jan 6, 2013 | 07:43 PM
SpeedCrazie's Avatar
Interested to see how the intercooler piping is going to be routed. Will this setup retain factory radiators
Old Jan 7, 2013 | 04:21 AM
t6378tp's Avatar
Turbo 3.5
it will retain the rad but aftermarket fans are required
Old Jan 8, 2013 | 03:11 PM
Quickywd01's Avatar
Old Jan 8, 2013 | 05:28 PM
t6378tp's Avatar
Turbo 3.5
Originally Posted by Quickywd01
sameside intercooler, bottom thur the rad support the upper around the inner fender and thur the battery tray
Old Feb 6, 2013 | 07:57 PM
bds1304's Avatar
any updates?
Old Feb 7, 2013 | 04:38 AM
t6378tp's Avatar
Turbo 3.5
yeah I'll get some new pic's posted soon
Old Feb 8, 2013 | 07:46 PM
Redline Maxima's Avatar
Do u keep fogs with this setup?
Old Feb 9, 2013 | 04:51 AM
t6378tp's Avatar
Turbo 3.5
yes
Old Feb 10, 2013 | 08:21 AM
t6378tp's Avatar
Turbo 3.5
Old Feb 12, 2013 | 10:33 PM
grksoccerkid91's Avatar
wow, this is a badass setup. looking good man! I haven't really accomplished much w/ my setup, probably leaving my turbo piping the way it is but doing my intercooler setup the way we/you showed me since i liked it a lot. Where do you get your same side intercoolers from?
Old Feb 13, 2013 | 03:54 AM
t6378tp's Avatar
Turbo 3.5
thanks, I get the intercoolers on eBay either cx racing or just intercoolers I think is the seller names
Old Mar 14, 2013 | 03:23 PM
bds1304's Avatar
What exhaust bends did ya use to make this, thinking bout building this set up for mine,
Old Mar 14, 2013 | 04:56 PM
t6378tp's Avatar
Turbo 3.5
45, 90 and pie cuts
Old Mar 21, 2013 | 06:15 AM
Richy Rich's Avatar
Juicy build
Old Mar 21, 2013 | 07:34 AM
sprocketser's Avatar
Badass job ! Subscribed .
Old May 1, 2013 | 05:46 PM
t6378tp's Avatar
Turbo 3.5
http://www.youtube.com/watch?v=7YiX7...ature=youtu.be
just amazed at how much boost the car makes at idle we revved it alittle
Old May 2, 2013 | 05:26 AM
ranmas2004's Avatar
What is the A/R on that turbo? What size is it? is that like a .58A/R??? What size feedpiping you use? 2.25" ? 2"?
Old May 2, 2013 | 06:34 AM
t6378tp's Avatar
Turbo 3.5
t4 .96 exhaust ar journal bearing, the crossover pipes are 2.5inches
.58 is too small for the projected rpms and hp, it would cause pre-turbo backpressure and possible burn exhaust valves
Old May 2, 2013 | 06:36 AM
t6378tp's Avatar
Turbo 3.5
lol, if it was a .58 ball bearing he maybe able to hit full boost just by revving the car
Old May 2, 2013 | 07:05 AM
akurtzer57's Avatar
My 3rd gen can hear bov real loud by reving in neutral. Doesn't actually build boost. I'm using tial 50mm knockoff.
Old May 2, 2013 | 08:13 AM
t6378tp's Avatar
Turbo 3.5
And that's way I put the dollar 4ft away from the bov for the nonbelievers
There are guys hitting 10-15psi by revving or 2 stepping so 5psi isn't unlikely
Old May 2, 2013 | 09:19 AM
mista0406's Avatar
Very nice build man can't wait to see numbers on this beast
Old May 2, 2013 | 12:19 PM
t6378tp's Avatar
Turbo 3.5
well I'll tell you it will be over 400fwhp seeing how that's when the party gets started around these parts
Old May 26, 2013 | 11:36 PM
t6378tp's Avatar
Turbo 3.5
http://www.youtube.com/watch?v=gC8bO...ature=youtu.be
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
