Do our cars only require a front end alignment?
Old Jan 17, 2013 | 02:05 PM
mclasser's Avatar
Are there any adjustable points in the rear axle? I have heard that in the back, they can add shims or something which technically affect the alignment but I'm not sure.
Old Jan 17, 2013 | 02:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
If the back is out of alignment, then the beam is bent, iirc.
Old Jan 17, 2013 | 02:16 PM
ShocknAwe's Avatar
They should check it but as far as aligning it, no not much room to play with
Old Jan 17, 2013 | 03:01 PM
foodmanry's Avatar
Da Roller Coaster!
Rear cannot be aligned. If the rear is out of alignment then you have a bent beam, or lowered to the point where it affects your alignment.
Old Jan 17, 2013 | 03:05 PM
celestialking23's Avatar
Would a bent beam create any issues? How would I go about changing it?
Old Jan 17, 2013 | 03:38 PM
Crusher103's Avatar
Excessive tire wear. Solution: Junkyard, get another one, install, realign.
Old Jan 17, 2013 | 04:19 PM
nsnrider's Avatar
rear beam replacement is pretty straight forward, the only thing to look out for is the e-brake cables, sometimes they give some trouble if you live in northern climate with salt.
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 12, 2015 01:54 AM
Team STILLEN
Aug 10, 2015 04:29 PM
laparka66
Aug 6, 2015 09:36 AM
