HELP!! wrecked maxima won't start
Old Jan 11, 2002 | 09:28 AM
maximaking's Avatar
Hey guys I know you all know alot more than I do so maybee you can help me out.... I wrecked my maxima and thre was some damage to the front end and the underhood fuse panel all the fuses are good the elctrician and the bodyshop mechanic can';t figure out what is going on the car will crank and just not start. It acts as though it is not getting gas. There is not a check engine code. The car cut off after the accident and would not start back up. So here's what we got No check engine code. Fuses and relays all are ok car cranks but won;'t start. No physical damage to the engine is visible from the accident it stoped at the radiator
Help!!!! no rental car and I haven't had a car for 6 weeks now?
Thanks in advance guys
Todd
Old Jan 11, 2002 | 09:32 AM
Sprint's Avatar
Re: HELP!! wrecked maxima won't start
pull the fuel filter off and see if their is any gas in it.. you might not be getting any gas to the engine.. also.. you may want to check to see if your spark plugs are getting spark..
Todd
Old Jan 11, 2002 | 01:15 PM
Scruit's Avatar
U wanna try me young boy?
Todd
Very silly/obvious suggestion: Have you checked the fuel system inertia switch? It should have tripped in the accident and cut off ur fuel pump.
Old Jan 12, 2002 | 04:00 AM
maximaking's Avatar
Re: Re: HELP!! wrecked maxima won't start
Didn't know there was one.... where is it located?
Todd
Old Jan 12, 2002 | 06:28 AM
Sprint's Avatar
Re: Re: Re: HELP!! wrecked maxima won't start
Todd
on the drivers side next to the firewall
kjlouis
Nov 24, 2018 06:09 AM
Bruceharrison
Aug 9, 2015 07:56 AM
dauntlessmax
Aug 5, 2015 10:29 AM
Jcof88
Aug 3, 2015 10:43 PM
