Best Position For Subwoofer Box For Loudest Interior Rumble?
I have two 900w Sony Xplods, but a 480w amp. I know they suck and that's horrible balance but they were given to me as a gift.
I'm not an audio expert, but when I had them hooked up to my old car (02 Pontiac Sunfire) these things hit HARD. I'd have to keep them on the lowest setting possible to keep my amp from overheating and they shook my whole car. but With my Maxima, now it's like I can barely hear them when theyre turned up to max from my head unit. I didnt change any connections, they are bridged and both pushing out just as much power as they were before (if not more). They just seem real quiet. I'm thinking because the layout of the vehicle is different and larger compared to the Pontiac, but it doesnt seem like a big enough difference to make that much of a difference in sound quality. Am I doing something wrong?
In every car I've owned, the sweet spot for the sub box is facing the rear of the car about 6 inches from the trunk lid.
Sorry for not being more specific. I'm using the same wiring technique as my old car (6 gauge power amp to battery, 6 gauge ground, RCAs and blue remote wire down opposite side flooring to HU). I have the same aftermarket head unit I was using in my old car (with sub out control). I've attempted every position of the box in the trunk and I get the same overall sound.
A few other factors I should have listed was that the guy that helped me wire my subs in my old car didn't bridge them correctly (or maybe he did). He kinda spliced all 4 speaker wires together and lodged them in one of the speaker terminals of the amp, but I forgot where.
I have them bridged correctly (I think). I took L+ and R+, spliced them together, and connected them to the + bridge terminal, then L- and R-, spliced them together, and connected them to the - bridge terminal. They're both pushing out power, just no rumble
I'm not a professional, this is kinda the second time I've done a sound system myself. I did my friend's in his Crown Victoria. He had two 10" subs with huge golf ball size holes in them and a 500W amp, and his car rumbles. Like what the s h i t...
Make sure all your settings are right. When I first bought my speakers. I had to play with some buttons on the amp and change some settings in the headunit to make it hit as hard as I was expecting it too. When it was all said and done it was 10 times louder.
Correct. I thought that was the case too so I replaced the ring terminals I was using for the speaker wires, but still nothing. I'm yet to check the speaker wire of the actual subs yet because I have to unscrew them from the box, but that will be my first step before I start reversing polarities and s h i t.
So I rewired everything and tried every wiring combination possible, and I'm still getting weak sound. I really just don't get what the hell is wrong. Could it be that my subwoofers went bad?
Thanks for the help all. I think I'm going to just replace the entire system (other than my amp) and I think it was a problem with the box I had. I'm gonna give these ones to my girlfriend though since they still work, just not what I'm looking for.
Cheers.
Cheers.
cut out the rear decklid, mount them in the rear decklid, please look at my post in the audio forums, i have two twelves in a sealed box mounted in my rear deck, my seal on the back glass is probably going to fail soon, my roof also moves quite a bit, im loosing alot of sound because of vibration though, although you can feel the compression in the car, also at proper frequencies my eyeballs rattle.
Another thing to consider is the vehicle itself. There is a lot of sound insulation between the trunk and cabin, that didn't exist in your previous car.
The most bass is usually seen (If you aren't isolating from the trunk) with the box against the front of the trunk (rear bumper), and facing toward the cabin. You reduce back waves and allow the lower frequencies room to grow before hitting obstructions.
Though, in the 20Hz range, it doesn't matter, as the standing wave is 20' long.
James92SE
Oct 8, 2015 04:57 PM
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 14, 2015 11:28 PM
