bumper cutting
bumper cutting
does anyone have any experience cutting 95-96 gxe bumper to fit the oe foglights? if so, what's the best tool to use? and after it's cut, how does it look? anyone have any pictures? please help! 'm about to order my oe foglights and have to cut the bumper.
thanks.
jhlee
thanks.
jhlee
go to www.maximadriver.com, click on How2, go to Install Fog Lights.
jhlee
Didn't catch that you had a 95-96...your screenname is misleading! Don't know what to tell you about cutting the 95-96's...sorry!
jhlee
Re: bumper cutting
thanks.
jhlee
thanks.
jhlee
I did the install a couple of years ago. The kit comes with a steel template that you screw to the bumper to use as a cutting guide. The screws go into the part you throw away. I used a utility knife, but it was hard cutting. I had to make several passes to cut all the way through. Using a hair dryer to soften the plastic may help.
The kit also includes black rubber trim to dress out the hole.
Originally posted by piopremier
just from the experence of cutting plastic, i suggest that you make your cut an 1/8th shorter and then sand to where you want to be to get the cleanest edge
Originally posted by KWheelzSB
Four words:
Dremel high-rpm cutting tool.
This tool was born for a job like this.
Available at Home Depot, Lowe's, etc.
Four words:
My 96 fog light complete kit
has arrived. Total $197.99 delivered to my door from auburnnissan. I just installed the relay (piece of cake), and the new switch )piece of cake but longer time needed). No time to cut the bumper now but tried connecting lights to the hanging connector. It works just fine.
Yes the kit includes two cutting templates. Kit does not include the 15A fuse because it is already in the car.
The instruction is not accurate: It says the kit is not for GXE with no ABS and power seats,... My car does not have ABS, only has power seats.
Re: My 96 fog light complete kit
Re: Re: My 96 fog light complete kit
ive only seen that car i was telling you about once since the post, the reason it was missing the fog light was bc it was wrecked, had the digicam for a few days, then took it out, then the car finally showed up, sorry
magiconthetire
Oct 26, 2015 09:03 PM
Calabar
Oct 5, 2015 09:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
