transmission connector ?
Old Mar 7, 2013 | 07:27 AM
uptownsamcv's Avatar
i got my transmission back in my cra but i broke a sensor on it. the sensor is on the rear of the t ranny facing the firewall. on removal the wire got cut than when putting the tranny back in we totally broke the sensor.
im guessing its the reverse light switch???
Old Mar 7, 2013 | 09:35 AM
maximase86's Avatar
I love lamp.
Back side near the firewall is the vehicle speed sensor. The reverse switch is at the bottom of the transmission and is a rather large diameter black plastic cover with a wires sticking out and wrapping itself around to the top of the transmission.
S
Old Mar 7, 2013 | 11:39 AM
the one im talking about has a black connector and is on the firewall side and is a few inches under the shift cables....
Old Mar 7, 2013 | 05:27 PM
maximase86's Avatar
I love lamp.
Sorry, I was thinking 5-speed. That would be the park neutral position switch according to the FSM diagram (seriously...it is).
S
Old Mar 7, 2013 | 10:08 PM
my car has a 6 speed..
Old May 4, 2013 | 02:50 PM
dddanielek's Avatar
I just pulled my MT tranny to diagnose the bearing noise (release or input shaft) and busted the same sensor..
Did you get the proper anser and do you know what its called ?
Much appreciated..
Old May 4, 2013 | 11:32 PM
its the neutral switch. i got it for $16 on nissanpartzone.com , its harness was $36 . when you put the tranny back in zip tie the plug for that sensor to a safe spot and dont put the switch back in till the tranny is in. you will need a 21mm wrench. a deep socket didnt work for me and i had to actually go buy a 21mm wrench..
im not sure what it does but i think its so the cruise controll cant go on while your out of gear. engine starts while in gear. i probally would have been ok without it. i only replaced it cause i though it was lockign me out of reverse...
one good tip for putting the tranny back in is to put it up to the motor with the axle holes to the bottom than than twist it in place before you attempt to slide in the input shaft....
i had pulled my tranny out due to throwout bearing going bad at 175,000 miles. i ended up doing full OEM clutch kit, rear main seal, reseal oil pan , 2 motor mounts , both axle seals, gutted all 3 cats, new oil cooler hoses, serpentine belt, thermostat and ECT sensor, new front rotors and pads all around, megan racing springs and full stereo upgrade with sub and amp... i wanted to make sure i didnt have to do any repairs for a while after this... than 2 nights ago colil #5 went out on me.....
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
