98 Nissan Maxima, V6
Old Mar 7, 2013 | 06:56 PM
Wheezi3's Avatar
I have a 98 nissan maxima & the other day I noticed white smoke from the tailpipe & a few other things I have noticed that has me seriously stumped. 1st- White smoke from tailpipe.
2nd- Oil only one spark plug.
3rd- Idles up & down
4th- Hard shift into 2nd gear.
5th- After trying to drive it, the idle goes up & down & then eventually shuts itself off.
Old Mar 7, 2013 | 07:35 PM
chrome91's Avatar
wrong section, you want the 4th gen section. but
1- white smoke if its cold outside is just water vapour, if its thick and sweet smelling youre burning coolant probably
2- could be a valve cover gasket leaking
3- could be many things, check for vacuum leaks to start
4- check the fluid level and condition if its a automatic, if its a 5spd check the fluid level. if its a 5spd its probably synchros or a linkage issue
5- again check for vacuum leaks, or scan it. might come up with a MAF code
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
