Has anyone here done dual rear exhaust
im looking to do dual rear exhaust not for performance but because i like the look. I know that i need to get the rear bumper cut but i like to know what else do i need to get ather then a going to a mufler shop. Thanks.
Re: Has anyone here done dual rear exhaust
Re: Re: Has anyone here done dual rear exhaust
Originally posted by guitaraus
PM 1/3there2/3togo i think...he had a picture of his max with duals on it before the big sig **** week.
Well...
They both have a single muffler with the tips split and running to the bumper. It is nothing special, but it looks and sounds good (from what I hear). If you want a true dual exhaust, arrafio is right - you have to cut into the spare tire well. That can be very dangerous and expensive. True, it would look kinda cheap if you look under the bumper and don't find a muffler, but like I said it is a lot cheaper than a true dual exhaust. If you really want something crazy, check out Greg @ CustomMaxima. He has 4 tips running straight off his catalytic converter. No muffler. He says its extemely loud, but sound good.
-Cyrus
-Cyrus
Re: Well...
-Cyrus
-Cyrus
Originally posted by cleanmax02
I know that Sx7r has done duals on his.. He even put the rectangular Z-28 tips on his.. It looks really sweet
a functional dual exhaust system on a maxima will have both a good side and a bad side. Good side is that it will make your car look really cool, bad side is that it will decrease your peak performance because although it may seem to be more easy flowing......there is a restriction.....which is the splitter that allows you to attach two b-pipes......
dual exhaust setup
I was just browsing through recent posts and came to this thread. If any one has good under the car PICs I would be interested in seeing them. If there is enough interest perhaps Dallas and I could offer a dual b-pipe set up. truaxdan@mn.astound.net No idea on pricing until we see what is actually needed.
Dan WSP
Dan WSP
Re: dual exhaust setup
Dan WSP
Dan WSP
Dual exhaust set up
I can tell you this, if we decide to do a dual set up, it will not be $1K. PICs, I need detailed ones from the Cat back, both sides and the year of car as 95-96 and 97 up are slightly different, they have to be shot under the car.If we use 304 SS it will be alot more expensive than if we use aluminized steel. Please let me know diameter of pipes used as well.People have said that all a dual set up does is increase weight and help looks. It may take away from performance. I will be sure to show Dallas this thread.I know he has a vendor working on several mufflers that could be used or would you all prefer a bring your own muffler application? Many people like their car quiet, some like it loud.What if we supply the pipes and you add the muffler?
Dan WSP
Dan WSP
Come on people get this man his pics!!! Any idea at all on pricing? Anyway you can do a few different options, such as a light weight option, a heavy cheap option, and a durable long lasting in snow and salt option, etc. I think if you can get a good deal on a few different mufflers you should have the whole kit. I know that I'll want a 3in muffler for both that isnt too loud.
Re: Dual exhaust set up
Dan WSP
Dan WSP
take a look for yourselves:
I have seen Kirk's car in person..1/3there...whatever... It does look nice on cold days when smoke is billowing out. He had two different sizes of pipe because one side was Teed off the other (I think) so to even out air flow he opened up one side more than he other. I think he's sold or is selling his max
I think Dan may have spoken a little hastily on the gen 4, having spent many hours under the gen 4 the evaporative junk sits right square in the way of where I would run the driver side pipe. However, once I put the finishing touches on the subframes I'll take another look at it, I think a split junction with 2-2" or 1-1/2" pipes might be the trick. It should work fine on the gen 3 anyway.
Tomorrow we are finishing the stage 2 x brace on my 96 and the 2001 muffler install. (have jeep 4.0 cai to finish also)
We also are doing a little thing with the front section of the B pipe where we eliminate or replace the resonator and the "s" looking section on the 97-2001 where the o2 sensor plugs in right ahead of the resonator. It will also eliminate that crushed area all the gen 4 and 5 cars have right behind the resonator. So far tests have shown we can pickup at least 2-3 mpg when cruising and I know it will help exhaust flow as the crushed section behind the resonator is crushed to about 1" thick from its original 2" diameter.
We simply detach the B pipe from cat and then cut the old B pipe off in the lateral straight section about 14" after the front hanger (the one behind the resonator)and slip the new mandrel bent section over the end and clamp in place. We will have a specially designed o2 insert which will allow plenty of clearance (for the 1997-2001) and will offer the pipe with or without a resonator. It will eliminate the ground clearance issues for the stock resonator, I have never seen one yet that was not dented. Under $100 with resonator.
We are also making an adapter for the gen 4 mufflers to enable the installation of a 2000-2002 muffler.
Busy week ahead, we have several people coming in for sfc installs and we are trying to get about 40 sets complete. The Gen 4 sfc's will be the first available as our other 2 gen 3 and gen 5 cars will be in a little later this or next week.
Dallas
WarpSpeed Performance
Dallas
Dallas
Dallas
Suggestion...
I've seen this before on an MX-7... If you're going just for the look, you could have a "dummy" dual tip exhaust. That way, you'll have the bext of both worlds, the performance of a single exhaust, and the look of a dual exhaust. The other thing, you won't have to do as much cutting, and customizing of the rear end.
-Jason...
-Jason...
Re: Suggestion...
-Jason...
-Jason...
Yes, you could do this... and you could also remove your coils to slam your car... but people will be laughing their asses off at you when they see exhaust coming out of only ONE side the second you start it up.Thanks, but no thanks! I think the idea on 1/3 there...(whatever)'s car that nigelcmf mentioned is a good idea - T one side off with bigger pipe to even the exhaust flow.
.....I think a split junction with 2-2" or 1-1/2" pipes might be the trick. It should work fine on the gen 3 anyway.
Dallas
Dallas
Re: Re: Suggestion...
Sorry... MX-6. I saw this setup in a warm climate... so the exhaust, wasn't noticeable, so he didn't have that problem. But, it was just a suggestion.
Jason...
Jason...
Originally posted by Bman
You mean MX-6 or RX-7???
Originally posted by Synki
Dallas, any word on the 4th gen B-pipes? Will you be making any of the B-pipes w/o a o2 sensor hole? I have a 4th gen cali. Materials? Mandrel bends? Thanks.
We will be doing the 2-1/4" and 2-3/4" B pipes when they run those diameters next. It takes about 4-6 hours to change tooling so it is difficult to run more than 1 or 2 sizes a week the way they are set-up. I have 2 sample B pipes there for them to work with already and will have the B pipe installed on my 96 to make sure all is well. It is a 5 hour drive to their shop and we usually work on all the configurations in that diameter when I am there.
(Since we have to actually add the 02 insert it saves us money if you don't need the insert. The 95 and 96 should not need the o2 insert as theirs is in the converter. The 97 up look like they all have the o2 behind the converter.) Hey, if you need something special we'll do it if at all possible.
Hope that answered your question.
Dallas
Kirk
If you have any questions PM or Email me.
Re: Re: Re: Well...
Originally posted by 1/3There2/3ToGo
Yes, I sold him my old one and put on a quiet dual-exhaust as I am selling the car
Guys, if you could only see what is sitting in my garage right now
And even tho it's florida we still get alot of steam outta the tips right now and DAMN i can't wait for dual smoke
....thank God for Mr. Macklem.
BTW, Did you get the check yet Kirk? Should be their anyday.
....thank God for Mr. Macklem.BTW, Did you get the check yet Kirk? Should be their anyday.
You are going to love the sound of those also....its an awesome purrrrrr.Oh...and you are very welcome, it was a pleasure doing business with you.
Kirk
I had to search for it!
