going back to bose,,,i think
Old Jan 13, 2002 | 09:37 AM
ZIPPIN's Avatar
Mauja He Mauja
ok i took out the whole bose system, after blowing the sub..i put in a kenwood kdc-9015 and an alpine eq,,,changed all 4 speakers..anyway long story short,,, i just don't like the way the HU looks. so i am thinking of putting the bose back in and just getting the converter to run the amp and 2 subs....
here is the question,,can i use the bose hu, and run pioneer 6.5
3-ways with it,,,or would i have to take out the pioneer's and put back in the bose speakers??
any ideas/suggestions will be appreciated
Old Jan 13, 2002 | 09:56 AM
Maxstilln's Avatar
You can use the Bose hu but you need to buy an adapter to convert the output to your amplifers. Keep in mind there is a chance that it might not sound as good using the adapter as if it was a straight path from the hu. Someone has the adapter for sale on the parts board I think he's asking $25 for it. Also make sure that the adapter by-passes the factory Bose amps, if not that's another thing you'll need to by-pass. Where did you put your hu in your dash? Which trim kit did you use? You might want to see about a different trim kit before taking out the aftermarket hu.
Old Jan 13, 2002 | 10:11 AM
ZIPPIN's Avatar
Mauja He Mauja
i used the soche kit from sounddomain.com. it matches the trim, but it doesn't look as good as the bose did..
thanks
Old Jan 14, 2002 | 07:38 AM
dwapenyi's Avatar
You can get the PD-4 from www.linkmeup.com. It'll do everything you want, mix a Bose HU with aftermarket speakers or vice versa. It's a little pricey, like $180 with the harness. I got the PD-4 and I'm running a Clarion dxz815 HU thru to my stock Bose speakers/amps.
What makes the PD-4 a good choice is that it is the only Bose converter, that I know of anyway, that takes the line out RCAs of your HU and feeds that clean signal to the BOSE. All those other $50 adaptors take the speaker outputs, which is not as clean.
DW
Old Jan 15, 2002 | 06:46 PM
95emeraldgxe's Avatar
OH NO!!!!! - he said the "B" WORD!!!!!
Old Jan 16, 2002 | 12:04 AM
Tony Fernandes's Avatar
thanks
Someone on this forum suggested buying a GXE stereo trimplate with a pocket in it for aftermarket applications. It should blend perfectly and look much better than your Sosche.
Tony
JRod28
Dec 29, 2023 09:56 PM
6spd4dsc
May 9, 2022 12:30 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
