Which Clutch Should I Get???
Old Apr 19, 2013 | 07:38 AM
DozerDave's Avatar
So my clutch is starting to slip and I was wondering which one I should go with. My car only has basic mods and I'm not out racing it. I'm not looking to spend a fortune but I don't want some cheap garbage. Lastly how do I know if I need to replace the flywheel also? Any help is appreciated.
Old Apr 19, 2013 | 07:56 AM
Max139617's Avatar
A 5th gen clutch would be perfect.
Or you could go with a EXEDY oem or Stage I which is what I have.
All of them are good sets
Old Apr 19, 2013 | 08:52 AM
cashoit's Avatar
Stock OEM replacement
Old Apr 19, 2013 | 09:15 AM
asand1's Avatar
If you have bad clutch chatter or visible hot spots (blue or black) in the flywheel surface, you will need to replace it. If the flywheel ran smooth and looks good you just need to hace it resurfaced at a machine shop.
Old Apr 20, 2013 | 12:50 PM
back2basics's Avatar
Definitely the 5th gen. I ordered all my parts through a Nissan parts wholesaler (it's a dealer in Illinois) and saved a bunch while still getting the OEM stuff I needed.
Has a stronger feel and is better than the 4th gen. clutch. It will fasten right up with no additional mods, just make sure that you replace the throwout bearing and if you have not done your rear main seal, this is a good time to get that out of the way as well.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
