Weight of Stock 15's, 16's and 17's
Old Jan 13, 2002 | 06:20 PM
Y2KMaxGXE-R's Avatar
Anyone actually weighted stock wheels off of their 5th gen? Just curious. Wonder how much my 15" with hubcaps weight?
Old Jan 13, 2002 | 06:26 PM
Telus.net
17" with tires @ 30psi is 40lbs.
Old Jan 13, 2002 | 07:08 PM
ehughes's Avatar
I have been thinking hard about some 17" SSR Comp's over my 2k2 SE 17's. If Stock 17"s w/ tires are 40lbs., what do the tires or rims weigh?
Old Jan 13, 2002 | 07:19 PM
RussMaxManiac
17's with tires are 50lb with 34psi.
I think at least 3 people have weighed them including me came out to the same weight.
Old Jan 13, 2002 | 07:21 PM
now how about the rims without tires? Since you guys are choosing rims by their weight without tires... Need weight of stock 15" steel, 16" and 17" alloy
Old Jan 13, 2002 | 07:27 PM
Telus.net
Rims without tire weighs a heavy 30pounds.
Old Jan 13, 2002 | 08:26 PM
are you talking about OEM 15, 16, or 17"? 30 lbs seems like awfully heavy even for 17".
Old Jan 14, 2002 | 11:36 AM
ehughes's Avatar
That's d@mn heavy! Dropping 10-15 lbs. off the wheels/tires would have to be good for performance!
Old Jan 14, 2002 | 03:05 PM
bump someone give me credible info
Old Jan 14, 2002 | 03:07 PM
Telus.net
The reason why those 17" are so heavy is because they are very dense, which is good for everyday abuse. In fact, someone here had an accident where the front tires blew, but the 17" rim remained in tact.
Old Jan 14, 2002 | 07:37 PM
guys are you f***n stupid, I asked you to give me the exact weights of these wheels. If you don't have them, then dont post here. Too much unneeded info.
Old Oct 9, 2002 | 01:37 PM
NYCe MaXiMa's Avatar
So stock 17s weigh 30 lbs without tires????
I think Russ's estimate is more or less acurate, because a 17" tire would weigh on average of 23-25 lbs.. the stock 17s are like 25 lbs...
stock 16s off a 5th gen are 20 lbs each without tires. I weighed them on a bathroom scale, came out to exactly 20 lbs. tires are another 20-22 lbs.. so 42 as a combo..
stock GXE 15s.. at least off a 4th gen are around 42 lbs with tires mounted.. I know because I had UPS weigh them.. I sold them as a package.. 2 wheels with tires mounted in a box.. that box, with 2 wheels/tires in it weighed 84.XX or so.. this is without hub caps.. which don't weigh much.
hopefully that helped..
i came across this thread looking for the weight of the stock 17s...
those things are heavy!
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
