GA PFTB adapter
PFTB adapter
I designed a PFTB adapter for the 3.5 swap for a buddy of mine and had several made. CNC machined from 6061 aluminum. Has a duel bolt pattern allowing either the 4th gen OEM TB or 01 PFTB to be mounted up. Get the 3.5 swap done initially using the 4th gen OEM TB and then upgrade down the road to the larger 70mm PFTB. Comes with all necessary hardware to mount either throttle body to the 3.5 FWD intake manifold. Simplify your 3.5 swap! $110 shipped.
Also, have some PFTB IACV block-off plates for sale as well a 4th Gen IACV apdater plate.
Yes, I could make a 00VI/PFTB adapter and do the same duel bolt pattern for the 4th gen TB if there was some interest. I have my 00VI setup still sitting in my basement so it shouldn't be too difficult.
how much would it go for? might be interested. i can get my own pftb and port match the manifold, just need someone to make necessary bop's and adapter plates for 00vi
Ok seems like there is a decent amount of interest. I'll get the ball rolling with a 00VI/DE-K version running the dual bolt pattern for both the 4th Gen throttle body and PFTB.
Originally Posted by Noir
Judging by the pics of the first, it looks like a bracket to extend the throttle cable mount will have to be used. Is there any way to incorporate that into your design for a cleaner/finished look?
Andy
Do you mean a DEK EGR guide tube block plate? The one on the bottom of the intake manifold?
Andy
If you get the TB bracket fabbed up I will buy this in a heartbeat! How many do you have left? Is there anything else that would be necessary to get the PF TB to run right on a 3.5? What do people do for the IACV on those on a 3.5? I have the PF TB on my DEK and had to get the OEM PF IACV to get it to start and idle properly.
You could use both the TB gaskets, one on either side or just some high temp RTV. I would just use the RTV.
. I about have the prototype bracket finished and then I will have some of them made.
