NJ WTB: z32 (300zx) 12.75" Caliper Brackets
Old Jul 10, 2013 | 02:25 PM
Diablo2424's Avatar
WTB: z32 (300zx) Caliper Brackets
I am looking for a pair of caliper brackets to mount the 300zx 30mm Aluminum 4-piston calipers to the 350z Brembo 12.75" rotors OR to the 13" Cobra Rotors.
These will need to be shipped to NJ (08723) unless you are local and we can arrange pickup.
Contact me through PM or reply.
Old Jul 11, 2013 | 06:24 AM
Crusher103's Avatar
Originally Posted by Diablo2424
I am looking for a pair of caliper brackets to mount the 300zx 30mm Aluminum 4-piston calipers to the 350z Track (Brembo) 12.75" rotors.
We typically dont use the 350Z rotors, its either the 6th gen Maxima rotors which are 12.6"s iirc or the Mustang Cobra rotors which are the larger 13" rotors. You are better off looking on Zilvia if you want the brackets to use 350Z rotors which will be more expensive than the options i have listed.
Old Jul 11, 2013 | 07:23 AM
Diablo2424's Avatar
Thanks for the heads up.
I am also interested in the brackets that mount to the 13" Cobra rotors as well, just no the 6th gen 12.6" rotors.
However, for the 13" Cobra rotors isn't some special ring also required? That's something I know nothing about :-\.
Old Jul 11, 2013 | 08:16 AM
Crusher103's Avatar
Not really, to make it completely hubcentric then yes there is a ring you have to use for them but in most cases no. I have the cobra rotors and im not running any rings or anything just the put the rotors on the car. Most of the time the clamping force of the wheel to the hub is more than enough to hold the brake rotor in place.
the ring you would have to get has to be 4mm thick to make it hubcentric and its a little difficult to find unless you have them custom made. Nissan hub bore is 66.1mm, Ford hub bore is 70.5mm. Most of this info is in the chassis section.
Old Jul 11, 2013 | 08:18 AM
Diablo2424's Avatar
Cool, thanks for the info. I'll see if I can find a pair of brackets for the Cobra rotors then, they are a little cheaper. But I will say the pair of brackets I found for $70 for the 350z rotors is tough to beat.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Calabar
Oct 5, 2015 09:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
