Got Greddy Exhaust today!!! Have question
Old Jan 15, 2002 | 08:40 PM
my01SE
I just recieved my Greddy exhaust tonight, just had a question, is there any thing that I should know before doing the install, or better yet, does anyone have a write-up on the install. I'm thinking that it's pretty straight forward, bolt-off, bolt-on... Feedback would be appreciated. . . Thanks.
Old Jan 15, 2002 | 08:42 PM
Dario's Avatar
exhaust installs are pretty straight forward, just dont forget to put something underneath the Greddy Exhaust when installing it so u dont scratch it on the ground.
Old Jan 15, 2002 | 08:48 PM
got rice?'s Avatar
squirt the bolts with Liquid Wrench before removing the bolts and again when they're off. It'll make it easier to remove down the road if you have to break them loose again.
Squirt the rubber exhaust hangers with WD40 or grease to make it easier to pull off. You might need a screw driver to pry them off.
Old Jan 15, 2002 | 09:15 PM
PhatGuy
Are these available through you still? What is the current price?
Does the b-pipe have a res on it? Can you check with greddy if just the b-pipe is available and at what price? Would a stock exhaust bolt on to the greddy b-pipe easily? We don't have a b-pipe avail for our cars... I hear Cattman is working on one though.
Old Jan 15, 2002 | 10:31 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
If you're not working on a lift, you need to remove the rear right wheel to get the stock muffler off and new muffler on (need to jack that side higher).
Old Jan 15, 2002 | 10:54 PM
the paragon's Avatar
did anyone install the HKS exhaust themselves? If so, how long did the process take?
Old Jan 16, 2002 | 09:36 AM
got rice?'s Avatar
I haven't looked at any 5th gen GReddy pics so I don't know for sure, but there probably is a resonator on the B pipe since all other GReddy exhausts have one.
No, full catback only. You can't buy bits & pieces.
Old Jan 16, 2002 | 10:04 AM
nvmymax2's Avatar
Greddy
When I got my exhaust I had to take it to a muffler shop and have an O2 bung welded into the b-pipe of the greddy because there was no hole for the o2 after the cat.
Old Jan 16, 2002 | 10:21 AM
Y2KevSE's Avatar
Re: Greddy
You have an O2 after your cat? Did you do the FED spec conversion?
Old Jan 16, 2002 | 10:22 AM
irvine78's Avatar
Re: Got Greddy Exhaust today!!! Have question
yeah..go buy a set of ear plugs while u at it.. j/k.
nice new toy~
Old Jan 16, 2002 | 10:30 AM
C2MAX
Re: Greddy
i was just about to say the same thing. yup its true. i had to drive over to a muffler shop to do the same thing and on the way there i forgot to tie up the o2 sensor and it dragged the whole way there! yeah well it happens to the best of us.
Old Jan 16, 2002 | 02:03 PM
my01SE
So I'll have trouble installing the exhaust do to the O2 sensor? That means i'll have to take it to the shop, which I really didn't want to do if it was an easy job, Is there any way to by-pass the O2 sensor? Please help, I wanted to do the install today. Thanks. . .
Old Jan 18, 2002 | 11:55 AM
MyownNismo's Avatar
Future Camaro SS owner
Does it matter where you live if you have a O2 sensor after the cat cause I just got mine today and if I have to do that it's not a problem because I work at a machine shop so I can weld a plug on.
Old Jan 18, 2002 | 07:33 PM
MyownNismo's Avatar
Come on answer my question above this one.
Old Jan 19, 2002 | 10:48 AM
MyownNismo's Avatar
Originally posted by RBa1aB
I didn't have any O2 sensor to worry about!!.. Is everyone driving a Fed Spec???
how hard is it to do without a lift.
Old Jan 19, 2002 | 11:52 AM
20thdriven's Avatar
geddy evo
My install bolt off bolt on in 30min, all O2 sensors are before the cat. the rear section (with muffler) of the system required a lift to allow room to snake the piping through.
Old Jan 19, 2002 | 12:14 PM
MyownNismo's Avatar
Re: geddy evo
Has anybody installed it without a lift here tell me how.
Old Jan 19, 2002 | 10:00 PM
MyownNismo's Avatar
Re: Re: geddy evo
Any other tips for me or do I have to pay $100 plus to install at a shop.
Old Jan 19, 2002 | 10:13 PM
K Pazzo 6's Avatar
Old Jan 19, 2002 | 11:04 PM
20thdriven's Avatar
geddy evo
install the front section in your garage (easy). if you can't snake in the rear section (muffler) go to a shop (w/o the muffler on, yes it's loud yet safe) and it will literally take 5 min once the car is lifted. i went to a shop with a lift and the guy did it in 3 min, literally, i said just leave but i gave him $5 as a tip.
Old Jan 19, 2002 | 11:26 PM
irvine78's Avatar
Re: Re: Re: geddy evo
$100 and plus?
what the hell? for any shop this shouldn't take more than 30 minutes!!
if they charge u that much, just do it at home. it's not hard..
Old Jan 19, 2002 | 11:54 PM
MyownNismo's Avatar
Re: Re: Re: Re: geddy evo
Originally posted by irvine78
$100 and plus?
They said they would have to look at it first but that's a estimate. any tips for me?
Old Jan 20, 2002 | 12:00 AM
irvine78's Avatar
Re: Re: Re: Re: Re: geddy evo
yeah, tell them to stop screwing around by charging u ridiculous amounts..
if u look at the GReddy, it's a direct bolt-on replacement...u don't have to fabricate anything to bolt on the exhaust..use the stock rubber exhaust hangers and that's it! takes like less than 30 minutes with a lift and air-tools..
Old Jan 20, 2002 | 12:11 AM
MyownNismo's Avatar
Re: Re: Re: Re: Re: Re: geddy evo
No tips for doing it myself with the help of a friend but doing it without using a lift.
Old Jan 21, 2002 | 11:58 AM
C2MAX
YES I DO DRIVE A FED SPEC
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
nismomaxgtr18
Forced Induction
20
Mar 5, 2016 08:04 PM
Trin1j23
Aug 12, 2015 08:31 PM
Jcof88
Aug 3, 2015 10:43 PM
