Very low idle - Code p0506
A few days ago I replaced my spark plugs on my 2003 Maxima V6 and had to remove the intake manifold.
Now I'm experiencing a very low idle (around 300rpm) and I have to push the gas pedal while starting the engine or it will just start and stop 2 seconds later (the rpm drops to 0 unless I push the gas pedal for about 5 seconds while starting).
The service engine light is on and code reading reveals P0506 NISSAN - Idle Speed Control System RPM Lower Than Expected.
What should be my next step? I'm pretty sure I reconnected the intake manifold hoses correctly and everything is where it should be. Should I just start by cleaning my throttle body?
Thanks.
Thanks.
It most likely is the gasket leaking. Get a new gasket. Re-using old gaskets is not a wise thing. You don't need to put a sealant on, the original didn't have it. Using it is a type of insurance.
jchronis2552
Sep 21, 2015 05:52 AM
lrb6805
Sep 17, 2015 04:49 PM
