FL WTB- Ignition coils
Old Sep 18, 2013 | 07:09 PM
Lvt3's Avatar
WTB- Ignition coils
Having a misfire and need coils replaced. college kid so please dont try and tax me like some of the local jokers round here. 60 for it used is steep but maybe its the miami area
Old Sep 18, 2013 | 10:29 PM
Slamrod's Avatar
Not to doubt you whatsoever, but are you positive that your coil(s) are the problem? I only ask because i see you are a new member and while many misfire woes are the result of faulty coils, it could also be a result of old spark plugs, dirty fuel, dirty injectors, corroded wiring, among other things.
If you havnt 100% comfirmed it is the coil(s) i suggest you wait before pulling the trigger. I had a horrific misfire (cel told me knock sensor, cyl 4 misfire, multiple cyl misfire) and i nearly dropped a couple hundred on brand new oem coils (a side note, this misfire is what dragged me into this terrible place where i caught the dreaded mod bug - $2000+ later...). However after further investigating i did two round of techron injector cleaner which worked like magic - no more misfire or cel!
Long story short if you havnt confirmed bad coils then i highly recomend doing further investigation.
And to make this post not completely unrelated, if by some misfortune you still need coils in roughly ~1 month i will likely have my rear 3 coils up for sale as i will be doing a 00vi swap and will no longer need them.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
