well i bit the bullet and got the maxima...
Old Oct 26, 2013 | 06:06 PM
TTwizted13's Avatar
now going through and slowly starting to replace the things wrong with it.
i pulled 2 codes off the SES system. P0037, and P0138.
I understand one is an 02 sensor, but which one exactly is it? best place to source the replacement?
p0037 something with heating element?
any help on what to replace there?
thanks a lot guys!
ill get some pictures of it after i get it cleaned up a bit and worthy of better pictures
Old Oct 26, 2013 | 06:19 PM
DennisMik's Avatar
P0037 and P0138 are both codes for O2 sensors and both happen to be for the same sensor, Bank 1 sensor 2, HO2S2-B1. Bank 1 is the side of the engine along the firewall. Sensor 2 is after the pre-catalytic converter that is built into the y-pipe.
In the future please tell us what year as there are differences between each year model. For this question, it doesn't matter.
Old Oct 26, 2013 | 06:39 PM
TTwizted13's Avatar
thanks for the quick reply. loving the forum already!
its for a 2002 SE model.
is there a local/forum regular we can source parts from? or best to just go to advance or some local auto store?
Old Oct 27, 2013 | 12:00 PM
DennisMik's Avatar
While Nissan calls the sensor you need a Sensor 2, parts places call it a downstream sensor.
Most people buy new sensors rather than used sensors. Advance Auto parts or other parts places should be fine. Best prices are probably on rockauto.com if you are willing to wait a couple of days for the shipping. The stuff on e-bay is so hit and miss that I won't chance it myself. Driving with a bad O2 sensor won't really hurt the car.
Old Oct 27, 2013 | 05:32 PM
Chris Gregg's Avatar
Get Off My Lawn
Driving with a bad SECONDAY O2 sensor won't really hurt the car.
Edited for clarification. Bad primaries will effect fuel economy as they are the ones used by the ecu for fuel adjustments.
Old Oct 27, 2013 | 09:50 PM
DennisMik's Avatar
thanks
Old Oct 30, 2013 | 12:36 PM
trinistallion19's Avatar
Cheapest I got my bosh replacements were from rockaway. Com saved me almost $140 compared to Autozone for all four
Old Oct 30, 2013 | 12:41 PM
NmexMAX's Avatar
dot dot dot ...
You sure it wasn't rockauto?
Old Oct 31, 2013 | 05:47 AM
Most definitely came up to 285 for all four
Old Oct 31, 2013 | 06:08 AM
TTwizted13's Avatar
looking on rock auto for the o2 sensor, im very confused. i see i need a downstream sensor. but they have them labeld front and rear.
Looking to buy a bosch, can someone verify if this is the right part number?:
BOSCH Part # 15224 OE Type - Exact Fit; Heated; Wires: 4; Length (in): 31.5 One of our most popular parts
Downstream Front
Old Oct 31, 2013 | 06:35 AM
NmexMAX's Avatar
dot dot dot ...
Downstream = rear, upstream = front.
Old Oct 31, 2013 | 09:25 AM
TTwizted13's Avatar
ok...so is that the right part or not??? theres 2 fronts and 2 rears. as i said. im extremely confused....
Old Oct 31, 2013 | 10:11 AM
You need two of the 13968
One 15225 and one 15224
Old Oct 31, 2013 | 10:48 AM
TTwizted13's Avatar
why do i need 2? both codes shown are only for 1 sensor?
Old Oct 31, 2013 | 03:03 PM
DennisMik's Avatar
You only need to replace the one that is bad. I don't know why trinistallion19 said that, he must have been thinking of something else.
Old Nov 1, 2013 | 06:51 AM
Oh I'm sorry I thought he needed to replace all the sensors my apologies
Old Nov 1, 2013 | 08:08 AM
TTwizted13's Avatar
But im still stuck at. ... What one is it. The down stream front or down stream rear
Old Nov 1, 2013 | 08:20 AM
NmexMAX's Avatar
dot dot dot ...
Downstream rear. B1 S2, (Bank 1, sensor 2). Sensor 2 designates it is downstream. Secondary sensor.
Old Nov 1, 2013 | 08:53 AM
TTwizted13's Avatar
Thank you!!
Old Aug 16, 2014 | 11:30 PM
Unclejunebug's Avatar
I'm in the same predicament code wise (p0138) and will be replacing both bank 1 sensors and the upstream bank 2 sensor just to do it(already replaced the bank1 downstream and have about 108k on the odo). I hate to beat a dead horse here, but I still feel like it's unclear as to which Bosch downstream sensor is the correct sensor for bank 1.
As TTwizted13 points out, the schematic in post #2 shows each sensor labeled as primary(a.k.a. Upstream/Front) or secondary(a.k.a. Downstream/Rear). My confusion is around aftermarket parts being labeled as downstream FRONT or downstream REAR since both downstream sensors in Nissan's schematic are labeled as REAR.
As far as aftermarket parts are concerned do they consider FRONT or REAR to be Bank 1 or Bank 2? Based off the position of the downstream bank1 sensor I'd say the correct Bosch part is actually #15225 due to the added wire length and not #15224. So which sensor is the correct sensor?
Is there any functional difference between the two downstream sensors or is it just the wire length being different?
EDIT: Searched a little more and this seems to answer the question...
Originally Posted by 2kmax865
According to the P0138 & P0158 codes both sensors are down stream sensors, so you would use 2 15727 sensors. I would use the direct replacements, P0138 code calls for 15225 white cable color & P0158 calls for 15224 red cable color.
From the following thread (post #3)...
https://maxima.org/forums/5th-genera...parts-fit.html
Old Aug 17, 2014 | 09:51 AM
DennisMik's Avatar
The difference for the front and read designation is because of the length of the wire attached to the sensor. The sensors themselves are the same.
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
foodmanry
Sep 24, 2015 12:02 PM
dcam0326
Sep 18, 2015 04:52 PM
