Why does my cap say this
Old Dec 7, 2013 | 10:31 AM
CauzinDrama's Avatar
Just noticed this today.... Why does it say "H"
Old Dec 8, 2013 | 05:40 AM
barristan's Avatar
It's saying "fix your link".
Old Dec 8, 2013 | 05:45 AM
IceBerg's Avatar
Why do your wires look like they are not properly affixed to the cap or is it just me
Old Dec 8, 2013 | 11:35 AM
chrome91's Avatar
did it feel warm? the H might mean its hot or overheating
Old Dec 8, 2013 | 11:51 AM
It isn't hot, and when I noticed it I was getting ready to leave for work so it hadn't been used that day.
Old Dec 8, 2013 | 01:18 PM
All connections are good and clean. The positive looks close to the negative in this pic only because of the angle.
Old Dec 10, 2013 | 01:33 AM
Hectic's Avatar
It's a generic China made capacitor using a china made voltmeter. If it's not a malfunction, it's possibly indicating a high voltage situation. Check the running voltage with a multimeter.
Old Dec 11, 2013 | 05:32 PM
barristan's Avatar
Looks pretty close from where I'm sitting! I think I'd spin the red wire going to the dist block 180 degrees and rotate the other one 45 degrees.
Old Dec 11, 2013 | 10:08 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Just remove it, then you don't have to worry about it ..
Old Dec 12, 2013 | 05:35 AM
nismos14's Avatar
§è~® f®ÈÄk
Beat me to it.
But yeah, take it out.
Old Dec 12, 2013 | 10:53 AM
Just ordered a new cap today. If I did remove it it would wreak havoc on my alternator and battery even though I have a yellow top.
Old Dec 12, 2013 | 10:59 AM
Pearl96Max's Avatar
No, no really it wouldn't. Pull it out and leave the money in your pocket.
Old Dec 13, 2013 | 11:20 PM
Hectic's Avatar
Large caps are beneficial if you have power hungry equipment wired to the same source as the amplifier(s), in close proximity to each other, and far away from the battery. Helps to stabilize the voltage provided to the alternate equipment when the amplifiers hit.
Other than that they are mainly for show. A load is a load, and a charging capacitor will dim your lights virtually the same as an amplifier. And if that's the problem, it's time for a new battery and/or alternator.
But, to say they serve absolutely no purpose is wrong. They just don't serve much purpose for most systems, and people use them for the wrong reason.
Old Dec 13, 2013 | 11:41 PM
Pearl96Max's Avatar
Where did I say "serves absolutely no purpose" ? I said to take it out, yes, but nothing beyond that. This was a fairly accurate assessment based just on his wiring alone. If he has something in there that would require such a thing, then he has bigger problems based on just the wiring seen.
If someone has dimming lights, then they should use a cap .. on the headlight output and not nearly that big. People Really need to learn to solve the problem and not just what some shop or the interwebz say to do ..
Old Dec 14, 2013 | 06:54 AM
So your thought on this.
I have a 400 watt amp wired up and running my door subs, and a cheaper Nitro 2200 watt amp running my 15" Cerwin Vega.
With the gain up more than 3/4 I notice the dash lights slightly dimming to the beat. So that calls for a capacitor correct.
The alternator charges fine at 14.2 all the time and I have a yellow top battery that's less than a year old.
Old Dec 14, 2013 | 12:26 PM
Hectic's Avatar
True, you never said that.
A cap is just going to act as a middle man, I'm sure those caps have a relatively high impedance to lessen the drop when charging up, so it may help. But the problem is that your battery and/or alternator isn't keeping up with the draw from the amplifiers. Since you have a relatively new yellow top, I'm guessing most of the blame is on the alternator. Check the voltage at the battery while your system is pounding, I guarantee it's not sitting at 14.2v.
I've never had a large audio cap, though I have kind of wanted to get one for the reason I stated earlier. I'm not a fan of my sub amp robbing power from my precious equipment that is connected to the same dist. block. Anyway, I've had dimming issues before, which were completely eliminated with a new alternator. A 2nd gen alternator no less, with a lower output rating. Virtually brand new reman, found it at the junkyard, so I figured it was worth a shot. It's worked very well for a few years now. Of course my entire system only draws 350w maxed out so there's not a ton of stress on it. There is a constant 10a load though, so I don't want an overly power hungry system on top of that.
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
