Relay harness question
Old Feb 1, 2014 | 01:07 PM
JaCqEeZ's Avatar
Looking at my HIDs from trs and I just wanted to make sure I got it right before the install. So on the side opposite the battery the factory harness will not be used correct? And since the relay harness is being used then the connectors on the bulb that would normally go to the harness and the ballast are not used. So there will be three unused plugs correct? And if that is right, should I wrap the ends with electrical tape or is it fine to let them hang?
Old Feb 1, 2014 | 03:13 PM
JaCqEeZ's Avatar
Also, I know the ground wire with the fuse goes to the battery, do the other two just get grounded where ever you can?
Old Feb 1, 2014 | 04:56 PM
Kmoney's Avatar
correct!
Old Feb 1, 2014 | 05:55 PM
WiSeGuY187's Avatar
It sounds confusing but its **** sinple when your under there
knight_yyz
Nov 6, 2015 02:34 PM
