Cooling fans upgrade help
I was going to post this in the "Advanced/Peformance" section, but I figured this is more of a general question.
I have a 1999 Maxima (Turbo'd) and it currently has upgraded fans (Slim). One of the fans came loose and melted on my downpipe. I'm sure it can be taken off with some work, sanded down and fixed. I'm afraid of the same issue though happening again. This causes the fuses to blow and no fans to work even though one is perfectly fine.
Are there any other options to upgrading these? Keep in mind, my original fans wouldn't work due to my piping for the turbo. I'm wondering if there is a giant single fan upgrade....
There are a few select posts on the slims....but are there other options?!!?
You can run a different size radiator, half the length but a thicker core that way the pipe to that side will clear. Or use that padded foil where the contact is and see if that helps.
Build a heat shield for your down pipe, wrap it, or apply ceramic coat it .....this I s way I ceramic coated my Cattman Headers there are really too close for comfort to all the plastic under the hood in the engine bay....
tarun900
19
Dec 20, 2021 06:57 PM
magiconthetire
Oct 26, 2015 09:03 PM
