Sponsored by:
Sponsored by: CARiD
Double Shimming a VQ35?
Old Feb 13, 2014 | 10:36 AM
aackshun's Avatar
What "Shims" do people use in their "double shimming" experiments on 3.5's???
VQ30 sure, I can double shim those buckets but...
VQ35DE? Rev-UP? HR? Da fuh you use to "double shim" those buckets?
Lets say I want HR Cams w/ HR springs, HR Retainers and HR Buckets in a 3.0 head what duh fuh do I double shim with?
Old Feb 13, 2014 | 01:10 PM
MoncefA33's Avatar
You shouldn't need to double shim the buckets, that's only ever been done on 3.0 engines.
Old Feb 13, 2014 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/all-motor/3...ec-charts.html
http://forums.maxima.org/all-motor/3...revup-etc.html
http://forums.maxima.org/all-motor/3...ta-2007-a.html
~140$ for 24 valve springs/48 shims from Courtesy.
Old Feb 13, 2014 | 04:59 PM
aackshun's Avatar
What shims? Which has been my question.... 3.0 shims? b cause 3.5's do not use shims.....
[edit] The answer I've been looking for is here...
http://forums.maxima.org/1626393-post5.html
I've been going about this all wrong, the goal that you guys have been talking about was to increase pre-load on the spring, not shimming the buckets (which is what I thought was going on).
Back to work for me.
Old Feb 13, 2014 | 11:03 PM
mightyMax95's Avatar
i'd like to point out
a) i'm the one that finally found the answer to that question
and
b) there's a missed opportunity to respond to nmexmax that "i searched and saw those, but they didn't have what i'm looking for..."
Old Feb 21, 2014 | 08:48 AM
NmexMAX's Avatar
dot dot dot ...
I bought my shims from DAVEB.
Originally Posted by PM from DAVEB Circa 06-20-2008, 05:53 PM
Springs-
24@ 44.14- $99.36
Shims- 24@ $1.24- $29.76
Old Feb 28, 2014 | 09:20 PM
Chris Gregg's Avatar
Get Off My Lawn
Can someone educate me (Readers Digest version) on the shims. I've not done head work on the VQ30 or 35. But, I know on the VG that hydrolic lifters are used and fill the gap between the lifter itself and the rocker arm. I also know the rocker arms have little steel "caps" between where the aluminum rocker and the top of the lifter meet. Are these caps what everyone is referring to as a shim on the VQ's?
Just trying to understand a shim. In my mind the hydrolic lifter should be filling any gap once it pumps up. Though, it makes sense that by having a larger shim, it would in effect increase how far open the valves travel each time they move. I can see the benefit of doing that as opposed to modifying the actual cam.
Thanks!
Old Mar 5, 2014 | 10:21 AM
NmexMAX's Avatar
dot dot dot ...
mclasser
22
Nov 12, 2020 01:58 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
BrandonCause
Sep 20, 2015 10:20 PM
