98 Maxima SE vs 99 Infiniti I30 gauge cluster
Will a gauge cluster from a 99 Infiniti I30 work in my 98 Maxima SE?
Also, will the IACV from that I30 work in my Maxima?
Lastly, what about the side mirrors?
Thanks.
Thanks.
The throttle body for Maxima and Infinity have the same part numbers, but the part number changes for the 99 model.
95 thru 98 = 16118-40U11
99 = 16118-38U13
I'm trying to find the IACV part numbers, but so far = fail.
99 = 16118-38U13
The Iacv will work, It is slightly different on the 99 because they are made smaller than the 95-98 Iacv. Only thing it will affect if you do swap it, from my experience, is the idle speed when you run the A/C put a load on the engine it wont stabilize/ idle wont go higher under load, it will drop.
Slamrod
Apr 10, 2016 05:24 PM
kirkhilles
Aug 8, 2015 10:53 AM
