Stillen RSB questions
Hello All Stillen RSB Owners,
A couple of questions:
1. Does the bar "bang" against the rear axle under hard cornering or when encountering a big bump?
2. Is it still possible to use the axle as a jack point?
Thanks All.
Thanks All.
RSB
the car should be mounted directly under
the rear axle. i had to grind off a brake
line bracket for the RSB bracket. i had
the same problem but now the ride and install
is flawless. use factory jack points.
Re: Stillen RSB questions
Thanks All.
Thanks All.
u can use the axle as a jack point. but do try using the factory jack points most times..
Re: Re: Stillen RSB questions
Originally posted by irvine78
the 'bang' happens if you don't align the bar correctly..make sure the bar clears the rear control arm housing. if u lined up the RSB right under the beam, it won't bang any longer..
Uh oh. I knew something's wrong with my installation.
Re: Re: Re: Stillen RSB questions
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Stagnet04
Sep 14, 2015 11:28 PM
