Running Light Replacement Question
Old Mar 3, 2014 | 08:25 AM
2011_maxima's Avatar
Question Running Light Replacement Question
all,
I just purchased a 2011 SV last week I noticed this past weekend that the driver's running lamp lens is cracked/broken i called the dealership & they said that i have to buy the whole light assy. ($290) can anyone tell me if this sounds right & if anyone knows of a better way to either get a replacement or a cheaper way to fix it I can do the work I just want/need the part??
Thanks!!!
new owner (2011_maxima)
Old Mar 3, 2014 | 09:08 AM
Rocky Davis's Avatar
You can look on eBay for new/used or amazon or even Craig's list for a lot cheaper price there are aftermarket ones that start at $200 but the weather seals on them aren't that great after a while you will start to get moisture in them
Old Mar 3, 2014 | 10:38 AM
Thanks for the reply, I will look tonight at those options. I also found after a little investigating I came across these...
link: http://www.carid.com/2011-nissan-max...-16404118.html
i was wondering if these would be as close as direct replacement as possible?? also, anyone have any experience with the company and or product(s)??
thanks again,
Old Mar 4, 2014 | 07:12 AM
ok all, I ordered the light above & should arrive around friday. I jacked the car up last night & took a look around. The bottom valance cover is fairly easy to remove... once you figure out how the clips work I used a small screw driver (star head-t20) to remove the 2 screwes that hold the light in place. the light came right out & I unplugged it. Overall the remove & replace proceedure is not difficult at all & I think could be done by most poeple. It is insane that the dealer & or body shop charge upwards of $200 or more for this "work"... anyways when part arrives & I install it back in I will do a right up again.....
thanks!!
rtirbany
Sep 8, 2015 11:46 AM
JMag90
Aug 25, 2015 09:17 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
