5 point grounding kit info?
Old Mar 21, 2014 | 03:51 PM
bc's max's Avatar
Anyone that could please help with some direction on hooking up my 5point grounding kit. I got a hks kit but no directions. I have a idea where some go. But i am stumped on some others. Any help would be greatly appreciated....
Old Mar 21, 2014 | 11:11 PM
andi398's Avatar
Bump. I am interested in this info also
Old Mar 22, 2014 | 02:09 PM
DennisMik's Avatar
You need to bug the manufacturer. It all depends on how long they made the wires.
Old Mar 22, 2014 | 05:08 PM
colt149's Avatar
5 grounding
Read this link
http://racinglineperformance.com/sho...nd_Install.pdf
Old Mar 23, 2014 | 06:31 AM
bc's max's Avatar
grounding kit
Originally Posted by colt149
thanks for info...
Old Mar 23, 2014 | 09:08 AM
Bronxboi5's Avatar
So I went and got 8 gauge copper ground wire from lowes.... Can I use this?????
Old Mar 23, 2014 | 09:33 AM
colt149's Avatar
5 points ground
I used the 6 gauge, I bought it in autozone.
Read this link
http://forums.maxima.org/audio-elect...other-how.html
Old Mar 23, 2014 | 11:36 AM
dwapenyi's Avatar
For most of the ground connections, the gauge is not critical. 16 gaage would be fine, and probably still overkill for most ground connections.
The exceptions are:
Battery negative to starter/engine block
Alternator.
You usually don't replace those anyhow. Just clean them.
Old Mar 23, 2014 | 12:50 PM
colt149's Avatar
5 points ground
Any vehicle that run with 50 to 60 Amps alternator the recommended wire gauge is 10 , fusible link 14. While 80 amps alternator the recommended wire gauge is 8, fusible link 12.
Old Mar 23, 2014 | 03:58 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
Just based on experience I would recommend at least 4AWG for the battery ground supplement, starter ground, supplemental alternator ground and transmission ground. Most everything else however, you can get by with 8 gauge.
Old Mar 24, 2014 | 10:28 AM
Prophecy99's Avatar
Originally Posted by shinjiduo
just based on experience i would recommend at least 4awg for the battery ground supplement, starter ground, supplemental alternator ground and transmission ground. Most everything else however, you can get by with 8 gauge.
+1
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
